Old 10-21-2020, 08:33 PM   #1
jprodun1
jprodun1's Avatar
Drives: 2010 Camaro 1SS
Radar Detectors
What do you use?
Sent from my iPhone using Tapatalk Pro
jprodun1 is offline   Reply With Quote
Old 10-21-2020, 08:35 PM   #2
PeteD
PeteD's Avatar
Drives: 2012 2SS Victory Red with white st
I have a valentine one
PeteD is offline   Reply With Quote
Old 10-21-2020, 09:11 PM   #3
Rons1le
Rons1le's Avatar
Drives: 2015 Camaro 2SS RS 1LE AGM
Escort Max and run the app with it and its awesome.
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
Rons1le is offline   Reply With Quote
Old 10-21-2020, 09:12 PM   #4
InFiD3ViL
InFiD3ViL's Avatar
Lol, if I knew the date mine was made I likely wouldn't post it out of sheer embarrassment. Mine is an old ass Cobra ESD 7000 from back when the pyramids were being built and I was still what people would consider 'young'. 5th gens didn't exist when this was produced. Hell, I doubt the Concept Camaro was even put to paper yet. It was considered an 'affordable' detector even when it was first released, at sub $100.
But it works. Yes, it picks up every leaky ass signal, shopping center, and lane departure system out there, but it has saved me a literal fortune in tickets over the years. I know when it's not joking and when there really is a traffic cop scanning, so it is still serving it's purpose for now. One day I will replace it and put it out of it's sun bleached misery.
I have looked at that before and the features are insane. I know you can get it bundled with the Escort Dash Cam too (I run the VAVA 2K cam now). What does the app do? I ask because I have an Android head unit and it would be awesome to get alerts right on my stereo screen and speakers.
Edit: OMG, just did some more research and learned that the iDatalink head units when used with an Rr2 brain box can integrate the Escort Max 360 detector into the head unit. SICK!
Old 10-21-2020, 11:14 PM   #5
Rons1le
Rons1le's Avatar
The app is linked into the radar detectors in your area by GPS so when someone's radar detector hit gets a ka or laser hit it'll put it on the apps map kinda like waze also.
If we run hard on the freeway we run all three. Also has redlight cameras location on it too.
Old 10-22-2020, 12:03 AM   #6
ariZona28
Give speed a chance
ariZona28's Avatar
Here is my archaic unit. I can't drive with it on the freeway, seems like it is throwing out laser and K-band warnings more than being quiet. I'm so behind on this (and many other) form of tech. What gives all the false alarms anyhow? I turn the laser function off unless I'm in the boondocks. Guess I'll need to crack open the coin purse for a new gizmo but I don't want to spend a fortune and have the same false alarm issues.
ariZona28 is offline   Reply With Quote
Old 10-22-2020, 04:34 AM   #7
CPCNY
CPCNY's Avatar
Drives: 2010 2SS/RS, VR ext/Blk Int
Uniden R3
CPCNY is offline   Reply With Quote
Old 10-22-2020, 06:39 AM   #8
BostiPB
BostiPB's Avatar
Drives: 2014 Camaro 2SS/RS
Uniden R3
I previously had an Escort and it was good (to an extent), but when I had it, they really didn't ever support the products that they had out (I'm sure things have changed since). There was only ever one firmware update for the detector I had and then nothing. They never fixed any issues that the detector had, which could have been easily addressed in a firmware update.
2014 2SS/RS - Red Rock Metallic - Kooks Headers, Corsa Extreme, Factory Reproductions Z28 Rims, Pedders Coilovers, JDP Clutch Reservoir, Summit Racing Line Lock, GM Strut Brace, GM low profile splash guards, Roto-fab CAI, Oracle Ghosted Sidemarker Lights & Concept Mirrors, ZL1 Side Skirts, MGW Flat Stick Shifter, BMR Subframe Connectors, Eaton Truetrac, Yukon 4.11s, GForce Renegade Axles, Speedmaster79 Diff Cover, Offset Diff Bushings, Every Suspension Bushing Front & Rear Replaced with BMR Poly Bushings - 421HP 412TQ
BostiPB is offline   Reply With Quote
Old 10-22-2020, 06:46 AM   #9
mudwheel57
Drives: 2015 camaro 2LS
Valentine one. Saved my ass many times!
mudwheel57 is offline   Reply With Quote
Old 10-22-2020, 06:56 AM   #10
Nailbender
Nailbender's Avatar
Drives: Chevy Camaro hwse 2018 GMC Sierra 1
Valentine one
Nailbender is offline   Reply With Quote
Old 10-22-2020, 07:01 AM   #11
RupertPupkin
Drives: 2014 Camaro SS 1Le
Escort Passport 8500. Had it since I was 16. 32 yes old now. It’s been good to me.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 10-22-2020, 08:35 AM   #12
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '26 Corvette Stingray
Escort 9800ix
Old 10-22-2020, 09:13 AM   #13
hudson773
Drives: 2014 camaro SS
I always travel with waze
hudson773 is offline   Reply With Quote
Old 10-22-2020, 11:25 AM   #14
InFiD3ViL
InFiD3ViL's Avatar
Yeah, Waze has definitely helped me out as well.
