10-24-2020, 07:08 AM | #1 |
Valkyrie14
Drives: Chevrolet Camaro SS Join Date: Mar 2020
How long does M6 clutch last?
I just turned 80,000 miles. I am planning a cam this spring and trying to plan around what other upgrades I need. Doing some suspension work too. The cam should easily put me in the 600-640 rwhp.
I have been hearing some additional noise when I shift lately. When I am getting on it I have to jam it from 2cd into 3rd. When would I expect to replace my clutch normally? When does a dual clutch make sense?
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
10-24-2020, 07:50 AM | #2 |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
Personally I wouldn't do all you're talking about without doing a new clutch. Now that your at 80K and at the power levels you're talking it's a must, especially with the signs and symptoms you're describing.
I'm in basically the same situation my intentions are to go with the Monster LT1-S it should handle my planned power and still have reasonable DD characteristics. Also while you have the trans out there's a couple of upgrades you can do one being adding a bearing in the tailshaft and there's a bronze shift cup, plus get the remote bleeder and the upgraded throw out set up. Sent from my SM-T837V using Tapatalk
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
10-24-2020, 08:44 AM | #3 | |
Valkyrie14
10-24-2020, 09:44 AM | #4 | |
Sent from my SM-G973U using Tapatalk
10-24-2020, 09:44 AM | #5 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
I went through 2 high performance clutches within 9000 miles. Swapped to 4L80e.
10-24-2020, 10:40 AM | #6 | |
Valkyrie14
10-24-2020, 12:02 PM | #7 | |
10-24-2020, 05:29 PM | #8 |
Valkyrie14
Thanks, you mentioned Tick. I’m starting with their clutch reservoir.
11-24-2020, 08:07 AM | #9 | |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
LT1-S? Aren't you the guy with the F1a-94? Dude the LT1-S didnt last in my buddys P1SC car making 800. If I were you, Id get the LT1-SC triple. Drives excellent, holds anything.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
11-24-2020, 09:53 AM | #10 |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
My second LT1-S lasted 18 months.... Really considering the LT1-SC but Monster tries to talk me out of it. I guess because I street the car 99.9% of the time.
> 2021 Camaro ZL1 1LE A10 - power upgrades in the initial design phase > > Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily |
11-24-2020, 10:16 AM | #11 | |
11-24-2020, 11:39 AM | #12 |
Sorry, my bad.
11-24-2020, 11:41 AM | #13 |
I assume you were discussing the SC twin? The SC Triple has excellent street manors.
11-24-2020, 12:45 PM | #14 |
Talking about the Triple supposedly good up to 1150whp. The Twin is supposedly good up to 700whp. LT1-SC Triple up to 1500whp. I've learned that ratings are just numbers and your results may vary (actually, will vary). I do enjoy the street manners of the LT1-S Triple and it's very easy to drive in traffic or in a parking lot. No problems there other than the clutch currently in the car is noisier when the pedal is depressed. The other two I had were pretty quiet until getting worn (got noisier as they wore). It's been difficult trying to find the "best" clutch for the job. I wanna street, I wanna drag, I want my cake and eat it too.
