View Poll Results: Which?
Flat Stick, Black in Color 12 80.00%
Flat Stick, Silver in Color 3 20.00%
Retro Stick 0 0%
Voters: 15. You may not vote on this poll
Old 10-26-2020, 11:08 AM   #1
DMan918
Drives: 2012 Camaro SS Convertible 6MT
Posts Swayed Me - Now I'm Going MGW, but which one?
Hi All,
OK, gonna go ahead and give a MGW a try. Currently have the OEM hurst shifter, but hear such good things that I will sell that and get this instead. So.... I'm leaning toward the flat stick (but debating color) with black six speed knob, but want to see who here prefers flat stick vs retro.
Also, are there other knob options worth taking a look at? Definitely leaning toward black I think.
I have an inferno orange SS convertible, if that matters for decisions on color.
Thanks!
Mike
DMan918 is offline   Reply With Quote
Old 10-26-2020, 11:28 AM   #2
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
I have the flat stick, it took a little while to get used to the knob being in a different position due to the canted back design.
Old 10-26-2020, 11:34 AM   #3
fireman1153
Drives: 2010 Camaro SS
I have the flat stick and love it. The car has never shifter better or quicker. Plus the flat profile to me had an awesome look. Like said before, it does slant back some and felt different but after a while I like it better. I can sit further and more comfortable from the steering wheel but very easily reach and find every gear. Go flat stick.
2010 Camaro 2SS/RS - 416 stroker, F1A-94 procharger, BTR blower cam, Big Red race valve, AGP intercooler, Alky dual nozzle kit, ZL1 fuel pump with DSX Aux pump, DSX flex fuel sensor, Bosch 210 injectors, Mcleod RXT1200 clutch, MGW flat stick, Tick Performance Level 3 trans, DSS 3.5 aluminum driveshaft, Strange S60 rear, DSS 1400hp axles, Texas speed 1 7/8 headers, X-pipe and MBRP muffler delete, BMR lowering springs, BMR trailing arms and toe rods, Poly motor mounts, RevShift trans mount instert, rear sub frame braces, Tuned by Joey at Pure Fabrication in Panama City, FL
fireman1153 is offline   Reply With Quote
Old 10-26-2020, 11:46 AM   #4
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
I have the flat stick in black and had their shift knob originally until I went with a weighted shift knob.
ECS supercharger, Texas speed stage 3 boosted cam, Johnson 2110 race style lifters, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
Old 10-26-2020, 12:41 PM   #5
DMan918
Thanks all for your responses so far.
Thanks as well. What knob did you go to?
Old 10-26-2020, 02:00 PM   #6
Camaro2ss2010
I went with the brushed finish from the link below.
http://www.sweetknobs.com/?cat=5
Old 10-26-2020, 10:36 PM   #7
Quicksilver2SS
Quicksilver2SS's Avatar
Drives: 2SS/RS LS3 NPP
I just ordered a heavyweight stainless with etched pattern here, I went with 3/8-16 threads to fit the billet hurst. Then it's off to the powdercoater for a vintage Ivory coating.
Taylor 409's, BF Comp 2's, Z26 pads, Hurst billet shifter
Quicksilver2SS is offline   Reply With Quote
Old 10-27-2020, 07:55 AM   #8
DMan918
Ok I went ahead and ordered the flat stick in black, but just went with mgw’s black ball with six speed pattern. There’s a little bit of a lead time on them so time to change the knob if I wanted.
What was the reasoning for switching to one of the other options? Looks, weight? Did the weight really make that big of a difference in feel? Don’t want a low grade knob.
Old 10-27-2020, 08:04 AM   #9
Camaro2ss2010
The weight makes a huge difference. It helps reduce the notchiness between shifts.
Old 10-27-2020, 08:17 AM   #10
DMan918
Thanks. I take it the mgw knob offered is not heavy at all?
Old 10-27-2020, 09:31 AM   #11
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
I have a retro knob on mine. I like the look of the flat stick way better but I couldn't beat the deal I got. The ball knob is actually the most comfortable knob imo. The shifter I got, they guy included a white and black ball and their race knob.
Their knob isn't very heavy
Old 10-27-2020, 09:43 AM   #12
DMan918
I am going to cancel the knob and get something more weighted. Now it’s which!
Old 10-27-2020, 10:47 AM   #13
DMan918
Any thoughts on this one:
https://epcomfg.com/product/heavy-weight-shift-knobs/
or
https://www.twistedshifterz.com/coll...eed-shift-knob
Old 10-27-2020, 10:51 AM   #14
Camaro2ss2010
I looked at those when I got mine. I decided to go a little heavier but that was just my preference. The one from MGW is very light.
