Old 10-27-2020, 08:01 AM   #1
sinlinson
2016 2SS Convertible
Drives: 2011 Camaro 2SS convertible
Engine falls flat between gears
MY car has a random problem of the engine just falling flat when accelerating. Is there a rev limiter I 'm hitting? Happens during heavy takeoffs, not normal spirited driving. Happened before and after my SCT X4 tune. Car is a LS3, 6 speed.
sinlinson is offline   Reply With Quote
Old 10-27-2020, 09:26 AM   #2
Southern Comfort
No Tags/Habitual Violator
Southern Comfort's Avatar
Drives: 6.2 Z71
Rev limiter is likely what you’re experiencing.
Southern Comfort is offline   Reply With Quote
Old 10-27-2020, 09:35 AM   #3
Warship2k15
Drives: 2010 Camaro 2SS
Rev limiter.Make sure you are up to operating temps on the engine and trans before spirited driving.
If that doesn’t fix it then an adjustment to the tune is in order.
Warship2k15 is offline   Reply With Quote
Old 10-27-2020, 10:26 AM   #4
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
Turn off stabilitrac and traction control. Or at least do competitive mode. See if that makes a difference. If the vehicle detects or anticipates traction or driving conditions are not ideal, it will intervene. Pull timing, apply brakes, adjust throttle body, etc. Torque management can also be adjusted in the tune. Title states falls flat between gears, but your explanation is while accelerating. Do you mean between gear shifts?
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 10-28-2020, 07:55 AM   #5
sinlinson
Yes it seems to happen going from 1st to 2nd or 2nd to 3rd. What is the rev limiter set to from the factory? The car pulls hard and than just dies.
Old 10-28-2020, 01:22 PM   #6
mikeman
Banned
Drives: 2015 Camaro
Stock redline is around 6500 rpms. Are you trying to shift past that?
mikeman is offline   Reply With Quote
Old 10-29-2020, 02:53 PM   #7
sinlinson
I didn't think so, but I will have to pay closer attention. I did hit the limiter once on my SRT8 Challenger and the engine just stuttered a little, not fall on it's face.
Old 10-29-2020, 04:01 PM   #8
InFiD3ViL
InFiD3ViL's Avatar
Yeah, on these cars it feels like a massive fuel cut when you hit it...which makes sense lol. It is definitely not subtle.
