Old 10-29-2020, 07:30 AM   #1
BRZN
BRZN's Avatar
Drives: 2012 1LT
Rust Repair and Post Body Work Clean Up
Bought the car used in March of '15, she's a 2012. The car originally came from Michigan, and I have no idea how she was cared for those first few years. A bit of surface rust on the underside, but that's it, I thought. A few years ago it was obvious some rust was beginning on the left rear wheel arch. Last summer I had it taken care of. The seam sealer at the inner to outer rear quarter panel, inside the wheel arch was rubbed off somehow and it had allowed water, dirt, and debris inside the panel. Two weeks after the repair I could see tiny rust bubbles starting again. The same body shop attempted the repair again. This time it took two months for the rust to begin again.
Early this month I had it at a different body shop (owner has a 2014 Camaro) and used a clean section of left rear quarter panel secured, both inner and outer, from a wrecked car to be used to graft into the damaged area.
After the body work, the car needed cleaned up badly. The interior was overly dusty.
The exterior was covered in overspray. A nice two bucket wash and clayed, this took care of the overspray.
I applied a Graphene Ceramic Coating to everything on the car except the repaired left rear quarter panel. That area I'll address deeper into the winter after the fresh paint has had time to completely gas off.
I'll be keeping my fingers crossed the rust has now been taken care of. I'm not ready to get rid of her yet.
BRZN is offline   Reply With Quote
Old 10-29-2020, 11:24 PM   #2
myold88
myold88's Avatar
This is the only rust issue I've ever seen here on camaro5 in 10+ years. I would
bet that area has had prior body work on that 1/4 panel. My 11 year old '10 SS
doesn't have a speck of body rust after 8 winters in Northern Connecticut and 3
here in Florida. I hope your new repair holds up.
Old 10-30-2020, 05:51 AM   #3
BRZN
BRZN's Avatar
Drives: 2012 1LT
Nope, absolutely no evidence of prior bodywork in that area. Like I'd stated the seam sealer had been rubbed off somehow. Could have been from the plastic inner fender liner. It's now been replaced too.
Here's a pic of what was found on the first rust repair attempt once the inner fender liner was removed.
Yea, I've put larger wheels and tires on and lowered her, but there's no sign of any rubbing in the rear at all from the tires.
Old 10-30-2020, 07:49 AM   #4
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
Drives: Chevrolet Camaro SS
I live in Wisconsin and this is a big concern for me. So far all I have seen are a couple of spots on the bumpers when I had the covers off. Good luck, looks like the shop did it the right way.
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
Valkyrie14 is offline   Reply With Quote
Old 10-31-2020, 01:43 AM   #5
drew peacock
Banned
Drives: 2012 2SS INFERNO ORANGE
this is why my camaro will never see a winter or even a wet road..it's too precious for me personally to risk rust..plus my OCD will never allow it
drew peacock is offline   Reply With Quote
Old 12-04-2020, 01:33 PM   #6
myold88
myold88's Avatar
These cars don't rust like the old days. keep it in the garage and watch it depreciate. Not me. Mines been on several trips to
Florida, Georgia, Indianapolis, up and down I-95, Canada, etc. 63,000 miles in almost 12 years and still looks like new.
I drove it for 8 winters in CT when the roads were dry. Sorry, I just don't get the garage queens.
Old 12-04-2020, 07:01 PM   #7
prod
prod's Avatar
Drives: HHR
I have seen rust starting on the rear quarters of a 2010 that was for sale here in Toronto Canada, where you just dont drive your good car in the winter.
It was rust bubbles under the paint right on the horizontal line where the rear quarter meets the bumper cover. It looked like the original paint, carfax showed no previous work. It is a spot I will watch out for. I pointed it out to the salesman, but when I came back they had done a quick respray that was obviously meant to cover it up rather than repair it properly.
Another is the bottom of the doors, just above the seam. I have seen rust there on 2-3 camaros as new as 2013.
prod is offline   Reply With Quote
Old 12-05-2020, 05:52 AM   #8
BRZN
BRZN's Avatar
Drives: 2012 1LT
My '06 GTO "Garage Queen" sits in our garage. We don't have garage space for the rest of our vehicles, including my daily driven company car, my Dodge Magnum (utility vehicle), and our daily driven Camaro. The GTO is a garage queen because it doesn't have to be driven often, it's my toy, and what I spend winters constantly modifying.
Our '12 Camaro also had slight rust bubbles at the door skin seam under the passenger's side door. I had the body shop grind that off and re-spray that area too. I believe I got that taken care of way ahead of any type of major problem to the door. Time will tell.
prod, you should get that taken care of like I did soon. The first time I took ours to a body shop for repair we had a spot similar to the larger one in your pic. The body man told me there was no metal behind the paint. As soon as he sanded the paint off there was a hole. The problem with the first two attempts of rust repair to our car, was that just the exterior panel was repaired, nothing was done to the inner fender where the problem was originating. The rust began to show up again rather quickly. You may need to source another section of quarter panel to graft in as I did. The salvage yard where I found my repair piece had five different gen5 Camaros there, they can also be found on eBay.
Old 12-07-2020, 06:40 PM   #9
Cheap Guy
Cheap Guy's Avatar
Drives: 2011 Camaro SS
Michigan with its road salt is just brutal on cars. You’ll see cars that look perfect inside or from the waist up but then you check the wheel wells and pinch seams and the rot is terrible.
When I’m looking for used cars one of the first things I ask is where did the car come from. A lot of the issue with Michigan cars is owners don’t wash the undercarriage or don’t wash them at all after a snowfall that requires salting the road. Even on my beaters or daily drivers I’ll run them through a wash immediately once the roads are clear. I know folks here frown on drive through car washes but it’s the lesser of the evils.
My Little Mid-Life Crisis Cure!
First - 1997 Camaro 3800 Y87, M5, Green - Gone | Second - 1997 LT1 Z28, M6, Silver - Sold | Third - 1999 LS1 Z28, M6, Pewter, Almost Stock! - Sold
Current - 2011 Camaro SS, M6, black, 1LE suspension parts - Current
Cheap Guy is offline   Reply With Quote
Old 12-08-2020, 06:12 AM   #10
BRZN
BRZN's Avatar
Drives: 2012 1LT
I'm one of those that frowns on drive through car washes.
I own, and use an MTM Undercarriage Cleaner to spray down the undersides of our daily's. The tool connects to my (gas powered) pressure washer and blasts the undersides of vehicles with four 45 degree nozzles.
https://adamspolishes.com/products/a...AaAmr2EALw_wcB
Old 12-09-2020, 06:34 PM   #11
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
The factory seam sealer gets brittle over the years and just falls off. Common issue on most cars from GM.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 01-07-2021, 10:43 AM   #12
lbls1
lbls1's Avatar
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ
(laughing) Double sided galvanized steel panels. Phooey. It reminds me of my old cavalier. That thing was supposed to have double sided galvanized panels, but it had some of the worst rust I've seen on a 90's car.
Make sure that all of the rust has been cut out of the area to be repaired. It could be a bit late for this right now, but take note that on your next new car, you should seriously consider undercoating and/or a Ziebart type rustproofing. These are proven rust fighting methods that have been very effective against corrosion in the past. If you keep your car out of the weather and the salt treated roads, then you could gamble and not have the rustproofing. Otherwise, if you drive it in the weather then I seriously would recommend rustproofing and a good dose of cleaning and detailing.
Rust is very difficult to correct depending on how severe it is. Just grinding it off and applying bondo is like flushing money down the toilet. Rust has an uncanny way of showing its ugly head, as it will surely come back. Rust has to be completely cut out in order to effectively rid yourself of it. Do your best to keep your car out of the weather and treated roads. Have a designated daily driver for the harsh stuff.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic
'15 Malibu LTZ 2LZ Turbo
'14 CAMARO ZL1 Blue Ray Metallic
'25 Silverado 1500 High Country 6.2L
lbls1 is offline   Reply With Quote
Old 03-18-2022, 10:35 PM   #13
SaReNi
Drives: 2012 SS
nice work. car looks great.
2012 Camaro SS
SaReNi is offline   Reply With Quote
Old 05-29-2022, 05:02 AM   #14
moose517
moose517's Avatar
Drives: 2013 1SS
haha dang my car is doing it in the exact same spot! From IN so we see the same road conditions and such, odd that it started the exact same way! I'm actually about to tackle it again for the second time and I'm not hopeful on it not coming back, but finding shops around here that will even touch rust repair is hard to find XD
2013 1SS M6 | Bo-white ported TB | CAI Intake | JRE Race Scoop | Manzo headers/catback | BMR motor mounts | Revshift poly insert transmount | EE Catch can | GM Strut Tower Brace | SJM Line lock
moose517 is offline   Reply With Quote
