Old 10-31-2020, 03:56 PM   #1
ABM Camaro
ABM Camaro's Avatar
Drives: 2013 ZL1 A6 Camaro
Down pipes and solo exhaust question
Does anyone know if these: https://www.summitracing.com/parts/a...gaAhpqEALw_wcB
Will bolt up to the Solo exhaust without leaking?
Looks like the down pipes are 2 1/2 inch, and the solo exhaust is 2 1/4 inch.
We have been working on this one for quite some time and had to design and manufacture specific “new” products (2 ¼” Mach-X muffler and the Solo angled resonators) to accommodate the design constraints of the car and the very unhealthy natural engine harmonic.
– T409 Mandrel Bent 2.25” Free Flow Piping
– 4.5″ T304 Polished Stainless Steel Round, Beveled Tips
– T304 Stainless Steel (inside and out) Mach X Muffler
– Tuned J Pipes to eliminate drone!!
– Solo’s angled resonators used to calm the noise
– All braces are easily cleared
– Deep, rich, no drone exhaust note
– Fits all V6 convertible Camaro’s
– 100% Bolt-On!!
ABM Camaro is offline   Reply With Quote
Old 10-31-2020, 09:29 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
I don't suspect there's be an issue - the cat-back is 2.5" at the beginning, just like the factory pipes, then 2.25" after the centre muffler. The small section from the end of the down pipes to the muffler is 2.5".
KillboyPowerhead is offline   Reply With Quote
