Old 11-03-2020, 09:52 PM   #1
turtlezx
Drives: 2010 1lt yellow
hard to shift into 1st manual trans
2010 1lt v6
getting hard to get into 1st gear when stopped
Easier if still rolling
Any ideas what to do??
tyrtlezx
turtlezx is offline   Reply With Quote
Old 11-03-2020, 11:20 PM   #2
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
Drives: Chevrolet Camaro SS
Same.
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
Valkyrie14 is offline   Reply With Quote
Old 11-04-2020, 07:08 AM   #3
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Clutch?
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 11-04-2020, 07:34 AM   #4
co14camaro
Drives: 2014 Camaro
You can try bleeding the brake and clutch slave cylinder. I'm guessing its never been done. Over time the fluid starts to break down and cause issues with the hydraulic operation. Sometimes a full flush and fill can fix things.
co14camaro is offline   Reply With Quote
Old 11-04-2020, 08:01 AM   #5
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
Could be your synchronizers
ECS supercharger, Texas speed stage 3 boosted cam, Johnson 2110 race style lifters, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
Old 11-06-2020, 07:52 PM   #6
turtlezx
anyone else with same issue and what problem was found??
linkage setup or straight to trans? from shifter
Old 11-07-2020, 08:13 PM   #7
turtlezx
any 1???????????
Old 11-08-2020, 07:54 AM   #8
Sparko
Sparko's Avatar
There are a lot of parts that can wear or get damaged in the drivetrain. As stated, your syncros could be a problem, you could also have a bent or otherwise damaged shift fork. Does it grind when your shifting into first, that could be a faulty clutch/hydraulic component, or does it feel like the gear is blocked off? When you shift it into first and then start rolling does it ever pop back out of gear? Did this start suddenly or has it been problematic at an increasing rate/severity? How many miles are on the car? Miles would help to know if you're at a point where something specific has typically worn to a problematic point. What kind of troubleshooting and maintenance has been done already to the drivetrain?
You wouldn't walk into an electrical shop and say "my lights don't work, what could it be?" and then ask again after they ask if you changed your bulbs or plugged the lights in without providing more information.
2010 Camaro 2SS
2018 Charger GT+
2005 Cavailer LS S/C - Sold
'87 HD FXRT - Wrecked pending repair
Sparko is offline   Reply With Quote
Old 11-08-2020, 03:01 PM   #9
turtlezx
doesnt grind going in gear feels blocked off
doesnt pop out of gear
56k 1owner
started doing this 2k ago
clutch travel feels same
no fluid changes clutch or trans
Old 11-08-2020, 06:18 PM   #10
mikeman
Banned
Drives: 2015 Camaro
Bleed the clutch and then go from there.
mikeman is offline   Reply With Quote
Old 11-09-2020, 08:58 AM   #11
Sparko
Sparko's Avatar
Does it shift fine when the engine is off or does is give the same trouble?
2010 Camaro 2SS
2018 Charger GT+
Old 11-09-2020, 03:33 PM   #12
turtlezx
engine off smooth as butter with or without clutching
Old 11-10-2020, 08:06 AM   #13
Sparko
Sparko's Avatar
I would start with the hydraulic system. Check the hydraulic fluid, make sure it's topped off, no air in the line, and not gross looking. If that seems fine your clutch master cylinder could be leaking by causing the clutch to not fully engage. You should feel lighter pedal pressure if the master is leaking. If your throw-out bearing went you could have sheered some springs on the pressure plate, or at least worn and bent them. Sounds like the issue is likely in one of those areas, kinda just going to have to go down the line.
2010 Camaro 2SS
2018 Charger GT+
Old 11-10-2020, 07:42 PM   #14
turtlezx
pedal moves about 3/4" of free play
cant remember if it allways did that
seems most hydro systems are hard right on top no play
Any way to take up play?? agree a little more pedal travel would help to disengauge
clutch
