Old 11-07-2020, 09:57 PM   #1
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Roll Bar options
What are my roll bar options for NHRA 10.0 certification? I know I'm not going any faster than 10.0 so this bracket suits me fine.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 11-08-2020, 01:19 AM   #2
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
2008 and newer vehicles don't need a cage to go 10.0
ttshovel is offline   Reply With Quote
Old 11-08-2020, 05:33 AM   #3
TheFlyingBananaSS
I was told that's only on a car that's not modified. Not true?
Old 11-08-2020, 05:41 AM   #4
ttshovel
ttshovel's Avatar
I've never had a track tell me any different. Tons of non caged cars here running 10s without anything safety related
Old 11-08-2020, 05:44 AM   #5
TheFlyingBananaSS
Good enough. Thanks!
Old 03-10-2021, 12:50 AM   #6
LHRxDeadx
LHRxDeadx's Avatar
Drives: 2013 Camaro 2SS Inferno Orange
I’ve had several around Utah area not let me race because I added a supercharger to my ss. If your car is stock you can run 9.99 or slower if you have any mods you need the cage is what the book says pretty much
LHRxDeadx is offline   Reply With Quote
Old 03-10-2021, 07:57 PM   #7
brick59
Sucker Punch
brick59's Avatar
Drives: 2013 Black ZL1, 2022 Silverado ZR2
I'm using a RPM Roll Bar its good to 10.0, nice bar and looks good.
427 Dart SHP Pro LS Block, Callies Magnum Crank, Callies Ultra I Beam Rods, Diamond Pistons, AGP twin Turbos 6865, Mast heads, Cam Motion LLR cam, Morel tie bar lifters, Crower roller rockers, NW 103MM TB, ID2600 XDS, Fore Triple, DSX, E85, ARH Turbo Headers, Corsa, Jakes stage 5 4L80, Circle D, RPM Roll Bar, BMR, Carlyle Racing 15" conversion kit.
brick59 is offline   Reply With Quote
Old 03-10-2021, 08:23 PM   #8
Vegas Bound
Drives: 2013 Sparkly Red One
NHRA certified tracks require a 6 point roll bar for anything after 2008 that is faster than 10.0 or 135 mph.
IHRA tracks require a 6 point roll bar using the old rules. Much slower times.
Vegas Bound is offline   Reply With Quote
Old 03-10-2021, 08:24 PM   #9
Vegas Bound
Tell them your car is a ZL1 and you down badged it.
Old 03-10-2021, 08:29 PM   #10
Silver14
Drives: 2014 SIM 2SS
You may want to double check the rule book to make sure you're good regardless of what you hear on this forum. Or if there's only a few tracks you'll be going to, can ask them directly.
https://www.nhra.com/news/2020/2021-...ailable-online
You still planning on driving the car on the street? A head not in a helmet meeting a roll bar can be a bad experience.
Silver14 is offline   Reply With Quote
Old 03-12-2021, 03:13 PM   #11
TheFlyingBananaSS
I like this!! I'll see how it goes. Atco opens on the 27th. When I make that first 10 second pass if nobody comes over for a look see I should be ok. Other wise a padded roll bar is in my future. At least I have the right valve stems lol
Old 03-12-2021, 04:39 PM   #12
NoDakZ/28
NoDakZ/28's Avatar
Drives: 2014 Z/28 CTF
This is correct, you also need a driveshaft loop.
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM
NoDakZ/28 is offline   Reply With Quote
Old 03-12-2021, 05:41 PM   #13
Vegas Bound
Unless you are running at an IHRA track. Our cars do require a 6 point rollbar with times faster than 11.59 I believe, it could be even slower.
Old 03-12-2021, 09:16 PM   #14
ttshovel
ttshovel's Avatar
11.49 is where they require it but again, the tracks I race at here in ohio and even one in southeast Michigan doesn't enforce it. I've been running faster than my cert without issue even.
Test and tune nights are the nights to go, if they give you the boot stick with 1/8 mile and work the system
