Old 11-12-2020, 04:23 PM   #1
Dmpsix
Dmpsix's Avatar
Drives: Black L99 2SS/RS
Haven’t posted in forever and need help
Sorry it’s been years since I’ve posted and I can’t find anything via the search tool.
Anyways, I have a 2011 SS/RS
One of the HID Bulbs went out, not the Halo itself but the bulb that is primarily used for night driving.
For the life of me I can NOT find an OEM replacement and every auto part store tells me they have lights for the non RS that give off the yellow hue.
I found some lights here and there that give off a dark blue light, but I don’t want that. I just want OEM so it matches with the other bulb.
Does anyone know where to find these ?
Dmpsix is offline   Reply With Quote
Old 11-12-2020, 04:42 PM   #2
gtstorey
maybe this one?
https://www.rockauto.com/en/moreinfo...sn=912&jsn=912
Old 11-12-2020, 04:43 PM   #3
ADVMax
Sporting Foole
ADVMax's Avatar
I put these in -
https://www.amazon.com/CAR-ROVER-D1S...omotive&sr=1-3
They have a 10000K bulb that is bluer, the 8000K is a more white light.
Less than 25 bucks for 2 of them - such a deal.
ADVMax is offline   Reply With Quote
Old 11-12-2020, 04:57 PM   #4
Rafael205
Rafael205's Avatar
Drives: 2011 Camaro LS
Diode Dynamics offers these.
Rafael205 is offline   Reply With Quote
Old 11-12-2020, 07:11 PM   #5
pyroguy
Keeper of “THE list”
pyroguy's Avatar
Drives: ABM #832
+1 for Diode Dynamics
Check out my build thread
Old 11-12-2020, 07:18 PM   #6
DMan918
Drives: 2012 Camaro SS Convertible 6MT
Been very happy with my diode dynamic drls. I wouldn’t worry about being oem. Likely the life of the other bulb doesn’t have a ton of time left so might as well swap the pair.
DMan918 is offline   Reply With Quote
Old 11-12-2020, 07:33 PM   #7
InFiD3ViL
InFiD3ViL's Avatar
What you need is a D1S class bulb (or set of 2 preferably). OSRAM is the original manufacturer and is considered the best. I believe that 4300k is the stock color.
OSRAM D1S
Old 11-12-2020, 09:04 PM   #8
ADVMax
Sporting Foole
ADVMax's Avatar
OSRAM D1S
What he said above about changing them in pairs - yes, for sure.
And thank YOU for the standard “k” @4300. I had wondered what the stock rating was and hadn’t found that yet. These that I got were 8000, I’m really wondering about trying a 6000 just because? These 8000k units are bright but really I wonder if the lower number would be a whiter light and actually illuminate better?
I’ve threatened to fab some mounts and stick a set of Hella 500’s with 100 watt halogens in them on the front bumper. I like those lights, they’ll light up a mile of highway!
Old 11-12-2020, 09:24 PM   #9
InFiD3ViL
InFiD3ViL's Avatar
Yep! I made that mistake which I why I know to change them in pairs. I burnt out my passenger side bulb last year. I was in between paychecks and was low on cash so I couldn't really afford both at the time...they are like $50-60 per bulb. So now I have one bulb that is slightly more purple-ish than the other bulb. Luckily it isn't very noticeable, but it still bothers me.
I was actually thinking of going with 6ks next time too. I want something as pure white as possible. My LED DRLs are a very clean bright white and I want them to match those as close as possible.
Old 11-12-2020, 10:26 PM   #10
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
I run the diode dynamics 6000. They are a perfect match with the P13W in the DRL. Pretty bright with a long throw at night.
ECS supercharger, Texas speed stage 3 boosted cam, Johnson 2110 race style lifters, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
Old 11-12-2020, 11:14 PM   #11
hammdo
'It's an experiment'
hammdo's Avatar
Diodes here too ...
-Don
747 RWHP 794 RWTQ
Old 11-13-2020, 06:51 AM   #12
102SS
waiting at the tree
102SS's Avatar
Drives: SIM 2010 2SS/RS A6
Phillips makes a D1S C1 bulb and Amazon Rock Auto and Ebay have them listed.
2010 2SS/RS A6 Just a few bolt-ons and appearance doo dads
102SS is offline   Reply With Quote
Old 11-13-2020, 09:28 AM   #13
KenKat
KenKat's Avatar
Drives: 2014 2LT RS Summit White
I did this job on my 2014; it uses a D3S instead of the D1S for a 2011, but other than that, it’s should be the same. I used OSRAM bulbs that I bought on eBay.
Here was a really helpful video on the replacement procedure:
https://youtu.be/2CybG7ar0Sc
There’s a few videos out there about taking the bumper off or other crazy stuff; not necessary, you can access them from the back / under the hood. It’s a little tight quarters, but do-able.
KenKat is offline   Reply With Quote
