Old 11-19-2020, 12:19 PM   #1
Z ya later
Drives: Z/28
Z/28 brakes
What options are there for switching out the CCB brakes for a steel setup for track use. I know steel may not be quite as good on the track, but it's something that I can deal with. I want to try to preserve the CCB's due to the high cost and limited availability of replacement parts.
Does anybody have the updated part number for the front brake pads? Is GM# 22990625 correct?
Has anyone been able to find the rear CC rotors? It looks like the are becoming hard to find. Are there any alternate sources besides GM. Brembo perhaps?
Thanks
Z ya later is offline   Reply With Quote
Old 11-19-2020, 12:21 PM   #2
608RS
608RS's Avatar
Drives: 2015 2ss
i've seen guys swap over to the Z06 non CC brake setup here, if you do some searching you'll find some threads w/details. good luck!
608RS is offline   Reply With Quote
Old 11-19-2020, 01:03 PM   #3
AustexaSS
Build Date - Dec 08, 2014
AustexaSS's Avatar
Drives: 2015 Z/28, #1007, Black A/C Stereo
Girodisc
https://www.girodisc.com/5th-Gen-Camaro-Z28_c_1516.html
https://www.rdpstore.com/p-11654-gir...on-a2-172.aspx
https://competitionmotorsport.com/a2...ors-camaro-z28
Rear CC rotors here:
https://www.gmpartsstore.com/oem-par...ctMGwtdjgtZ2Fz
Looks like the front pad number has changed to 23284028
https://www.gmpartswarehouse.com/oem...RoC8ywQAvD_BwE
https://www.gmpartsdirect.com/oem-pa...bC12OC1nYXM%3D
Depending on where you order parts from you could get the correct pad (same as corvette) but the wrong wiring harness. You can reuse your old harness if you didn’t wear through the circuit wire.
AustexaSS is offline   Reply With Quote
Old 11-19-2020, 06:06 PM   #4
Z ya later
Drives: Z/28
I tried to order the rear CC rotors right after you posted the link, and I just received the notification that they are out of stock there as well.
Thanks for the links on the steel rotors, it is much appreciated!
Old 11-19-2020, 06:44 PM   #5
CAMARO_HEAVEN
Big John
CAMARO_HEAVEN's Avatar
Drives: Wife 2013 Camaro 2SSRS / ME?
Here's a couple front and rear
https://www.ebay.com/itm/2014-2015-C...oAAOSwvbRfNCOU
https://www.ebay.com/itm/2014-15-Che...AAAOSw4shX5Bdm
https://www.ebay.com/itm/2014-15-Che...EAAOSwtnpXm79~
https://www.ebay.com/itm/2014-2015-C...EAAOSw6RBfNwPo
And rear calipers
https://www.ebay.com/itm/New-2014-15...0AAOSw37VeXvZT
These are not mine just trying to do my part and help a member out.
Good luck
John
CAMARO_HEAVEN is offline   Reply With Quote
Old 11-19-2020, 08:47 PM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Try Ken at KNSBrakes.com they have the iron rotor conversion an he’s pretty reasonable.
Orange Krush II
Old 11-20-2020, 08:31 AM   #7
johna
Drives: 2015 White Z28
Regarding the rotors on a different point I think I also read on the forum you can buy some brake pads that sorta restore the rotor too.
johna is offline   Reply With Quote
Old 11-20-2020, 01:05 PM   #8
SIM GhostrdrZ
SIM GhostrdrZ's Avatar
Drives: ‘14 ZL1 M6 vert
Did you by chance get the CC rear rotors on eBay? If so, good buy.
SIM GhostrdrZ is offline   Reply With Quote
Old 11-23-2020, 07:27 PM   #9
Z ya later
Drives: Z/28
No, when I got there they were not available. It looks like all the vendors are sold out for now. I tried gmpartsdirect, and 3 different sellers on ebay.
If anyone has a rear set of rotors they would to sell pm me please.
Thanks for all the help, If anyone has any other suggestions, post em up...
Old 11-23-2020, 08:41 PM   #10
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Check Corvette Forum there’s some for sale there same rotor just different hat just swap them over.
Orange Krush II
Old 11-27-2020, 09:52 PM   #11
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Here’s a good deal on a complete set of CCM rotors, not mine but just trying to help out.
https://www.corvetteforum.com/forums...ic-rotors.html
Orange Krush II
