Old 11-25-2020, 04:10 PM   #1
Machh5
Drives: Camaro
Less Power
In recent weeks a few things have happened to my 15 LFX. I'm right at 100k miles and started noticing the car has lost power. It starts and runs good but it lost most of its mid range power. No other symptoms I inspected the air filter for leaves, the condition of the throttle body( no carbon build up). I do notice one thing is the high pressure fuel pump sounds noisy. Was quiet before this. Are there tests to check the high pressure fuel pump? The oil is clean no signs of fuel in it. This car has always ran very well so it surprises me its very noticeable. I always run it moderately hard to keep the cats clean and use fuel injection cleaner regularly, nut that long ago the valves were walnut blasted too. They really didn't look bad at all for 87k miles, just a small amount of build up, didn't even change how it runs after cleaning. Only other thing I can come up with is maybe the gas formula has changed with the cold weather. It feels like I put regular fuel in but I always use premium. The car always ran alot better with premium in it.
Machh5 is offline   Reply With Quote
Old 11-25-2020, 07:48 PM   #2
xstuntman
Drives: 2012 Victory Red LFX
Yeah, sudden increase in noise makes me think cavitation and there is a test for line pressure. Me, I'd take it in to get tested and based on what they report back fix it myself.
Not sure about the newer diesels but cavitation happened on the older ones back in the day.
'18 SS wheels, colored matched Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, victory red rotors and calipers, 1/4 window American flags, splash guards, AEM dry panel air filter, Hot Wheels steering wheel and seat covers, Hot Wheels exterior emblems.
xstuntman is offline   Reply With Quote
Old 11-25-2020, 09:33 PM   #3
Machh5
Drives: Camaro
Thanks for the suggestion, I may just change it out with a new factory part. Till I get it tested it just cheaper to change it. Its got 100k on it, probably time to change it anyway.
Old 11-25-2020, 11:24 PM   #4
Pearlj10
Drives: 2011 Camaro 2LT
Before you change the part out, if you have access to hptuners, or someone who does, you can monitor fuel rail pressure to see if the HPFP is performing or not. Just a thought.
Pearlj10 is offline   Reply With Quote
Old 11-25-2020, 11:33 PM   #5
Machh5
Drives: Camaro
No I don't but my scanner may be able to see it. I have no idea what it should look like spec wise.
Old 11-27-2020, 06:08 PM   #6
Machh5
Drives: Camaro
Running the tank low then refilling with fresh fuel seems to have solved the problem. Although I think the HPFP is a little noisy scanner says the pressure is good. I'll see what happens in the next few tank fills. I've tried to use regular in the past and the car ran terrible with it and thats exactly how its acting. I'm going on a 400 mile trip tomorrow so we'll see how it acts. I do notice something its never done before is at a idle it will miss once or twice then it gone. And not every time you drive it, very randomly. I had a pending code 301 a few months ago but it never turned the light on. I think all these never engines run a little rough cold when they get high mileage on them.
Old 11-27-2020, 07:06 PM   #7
BuddyLee
BuddyLee's Avatar
Drives: 2013 Camaro 2SS/RS
The engine is designed for 87 octane. Is that what you consider "regular"?
BuddyLee is offline   Reply With Quote
Old 11-27-2020, 07:44 PM   #8
Machh5
Drives: Camaro
It was tuned for premium. Scanner shows 2 fuel readings that read 44-43 PSI but It doesn't tell if its reading the low pressure or high pressure pump pressure. 44 PSI would be normal for the low side and 44 BAR would be normal for the high side. The scanner that reads 2 fuel pressure reading don't match. 1st reading fluctuates between 43-44 second is steady @44. I suspect the scanner is reporting actually reporting bar not PSI as it says. Anyone have a factory manual that could shed some light on this? Car is running good again and all the data looks perfect EXCEPT I can't decode the fuel pressure until I understand what I'm reading. The more advanced scanners I've seen online show high pressure fuel pressure actual and desired. Example will shoe 44bar actual and 44 desired. My 2 scanners only show 2 fuel pressures shown like this fuel pressure(00) 44 and fuel pressure(03) 44. They don't change together, 1 may report 44 while the other 43 and the (00) fluctuates. So I'm just guessing here the the (00) is the high pressure and the (03) is the low pressure. Thanks
Old 11-27-2020, 08:15 PM   #9
xstuntman
I wouldn't run 87 in mine even if it was free and pumped by swedish bikini models.
Old 11-27-2020, 08:32 PM   #10
xstuntman
Don't have the material for correct pressure but I am wondering if you saw different pressures from idle and higher rpm.
Old 11-27-2020, 08:46 PM   #11
spyderbuddy
Mine usually runs up close to 650-795 PSI.
that is fuel rail pressure
it 45 - 80 PSI at the Tank
Old 11-27-2020, 08:53 PM   #12
Machh5
Drives: Camaro
I scanned it in the driveway and everything looked spot on. I tried revving it and the fuel reading 1 varies 43-44 when I rev it, fuel reading 2 stays @44 steady. Fuel trims look perfect idle and revving. Driving I can't do here at night because too many deer walking around and I can't see well enough to read it while driving normally. I'm going on a 400 mile trip tomorrow, I'm going to try and watch the fuel trims while under acceleration etc. I may just replace both pumps to be safe. Its @ 99900 and tomorrow it will be 100k plus. Cheap enough to change both pumps after 100k of great service. The car runs ok and it may have just been poor fuel, who knows whats get dumped into the gas tanks today. But its always run excellent before this and I'd miss the performance it has. Very fun to drive with great gas mileage to boot.
Old 11-27-2020, 08:55 PM   #13
Machh5
Drives: Camaro
Originally Posted by spyderbuddy View Post
Mine usually runs up close to 900 psi or more.
How are you reading it?
Old 11-27-2020, 09:00 PM   #14
Machh5
Drives: Camaro
This car runs so bad on 87 its just stupid. Almost not driveable, it knock and ping and farts around enough to piss off the Pope.
