Old 11-26-2020, 08:05 PM   #1
Ravioli SS
Drives: 2011 Camaro 2SS
1" drop and wheel fitment question
2011 Camaro SS.
Looking at dropping 1" with BMR springs. I'm going to put TSW Jarama wheels on in spring to replace the stockers. Jarama's are 20x 8.5" with 265/35-20s in front and 20x10" in rear with 295/35-20 Nitto NT555 tires with hubcentric rings and wheel spacers for the rear (to clear the brembos). Will there be any issues/ rubbing? Thanks in advance!
Ravioli SS is offline   Reply With Quote
Old 11-27-2020, 09:17 AM   #2
Avenging Orange
Avenging Orange's Avatar
What offsets?
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 11-27-2020, 09:24 AM   #3
Ravioli SS
I'm not sure as I purchased the wheels second hand.
Just did a search on TSW website and the fronts can be either 20 or 35 and the rears could be 25 or 35
Old 11-27-2020, 12:39 PM   #4
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
If just drop springs . I ran tsw 20x10s on the rear with 35 offset. No issues and no spacers.
Fronts were 20x9 by 35 offset no issues. Ran 20x10s on front as well. Forgot offsets, but probably 20 offset
VR Baron is offline   Reply With Quote
Old 11-27-2020, 01:20 PM   #5
Ravioli SS
Thank you sir!
Did you time the bushings or get an alignment after the install? Planning on def getting an alignment but I called a few shops about timing the bushings and they acted as if I was speaking a foreign language.
Old 11-27-2020, 05:14 PM   #6
Ravioli SS
Just measured the spacers they are .25”
Old 11-27-2020, 09:40 PM   #7
VR Baron
Originally Posted by Ravioli SS View Post
Thank you sir!
I had hotchkiss and the bushings were timed.
And yes you need an alignment when lowering the car.
Old 11-27-2020, 09:42 PM   #8
VR Baron
1/4” spacers are to thick for stock wheel studs. 5mm is max. I run those on front no issues, and I autocross.
Old 11-27-2020, 10:02 PM   #9
Ravioli SS
would having aftermarket lug nuts compensate for the spacers and different wheels?
Old 11-27-2020, 10:06 PM   #10
Ravioli SS
I did test fit the wheels before buying and they seemed to fit fine
Old 11-27-2020, 10:35 PM   #11
VR Baron
No
Old 11-27-2020, 10:39 PM   #12
VR Baron
It’s not about fit. 5 mm is max. Any thicker and you don’t have enough threads on the stud and is not safe. You can get longer studs if desired. But with you’re wheel and tire size you do t need spacers. I run 20x10.5, 35 offset and 19x20.75, 35 offset on rear. No issues
Old 11-27-2020, 10:58 PM   #13
Ravioli SS
Thanks! I guess the only issue the guy who owned them before me had was rubbing with the calipers
Old 11-27-2020, 11:30 PM   #14
VR Baron
Who knows. Did he have a ss? If so shouldn’t have had clearance issues with Brembo calipers. Unless the spoke design, and even the wheel design was not made for our cars.
