![]() Drives: 214 SS 1LE SCCA T2 Join Date: Dec 2018
14' F/R Hubs/Knuckles/New ABS - Run 315 18" ? Sold
$420 + shipping, includes: hubs, knuckles, abs, wheel studs etc.
Brand new beginning 2019 with ARP NASCAR studs, Gorilla racing lightweight nuts, brand new ABS lines and sensors, with BMR and Z-28 bushings already installed. Fronts have been modified to allow 18" rims and 315 tires to clear using Brembo ZL-1 brakes in front. Still good for everything else, but if you want to go wide in front, this mod is done. Bill 440-591-0989 williamjmoore33@gmail.com Last edited by Msports33; 02-27-2021 at 03:16 PM. |
bump lower price
bump new lower price
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 ZL1 416 Join Date: Feb 2013
your getting 18" rims to clear zl1 front calipers
how is this done? Link??
2011 2SS/RS Convertible, Victory Red, Roto-Fab CAI, Stainless Power 1 7/8 headers, No Cats, Straight piped, Bo White TB, Circle D, 3.91, ZL1 CONVERSION, CDC Roll bar and some powder coating and dipping.
#6 |
With the mods on the front knuckles here. The ZL-1 Caliper will easily clear a 18" wheel ( depending on wheel offset) and you can run 315's front and rear. Have been running this mod racing for GM since 2014 and it works. I ran Forgelines all around and ran a 4.5 mm spacer up front.
#7 |
ok so whats the mod ?
#8 | |
![]() Drives: Zl1 Camaro Join Date: Nov 2019
So what mods where done? Just longer wheel studs to run spacers on the front? Msports33 I'd like to pick your brain sometime about a zl1 suspension setup just to get your thoughts. |
#9 |
Knuckle on front is machined down to accept 18" wheels
#10 |
#11 |
Please look closely on front knuckles, they are shorter.
#12 |
Hope this helps
#13 |
i see the light
#14 |
lower price
