![]() Drives: 2010 Camaro SS 2SS Join Date: Aug 2016
Brake rotors
I'm looking for a good source for OEM style brake rotors and pads for my 2010 SS Camaro. I'm not looking for a performance upgrade. I just want to find rotors that don't rust and pads that wont turn my wheels black with brake dust..Any suggestions?
It don’t come easy.
I’ve noticed posts that stated ceramic pads as more forgiving on brake dust. I believe Hawks brand has been mentioned.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
I went with a set from R1 Concepts. Geomet coated rotors (should hopefully not rust) and a set of their ceramic pads.
They are a vendor here and offered a good deal for all 4 corners
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
![]() ![]() ![]() ![]() Drives: 2014 Ashen Gray Convertible Join Date: Apr 2017
To ultimately get no brake dust best bet is to revert to a bicycle, huge savings and don't have to worry about rotors rusting either!
#5 | |
By the way, the new bicycle rotor/brake systems create some dust. Maybe a skate board.
#6 |
^^^^ yea, that is always a good way to start Monday, with a smile!!! On the other note, I went with the AC Delco Professional semi metallic pads and OEM rotors when I did mine and the dust is really very minimal.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
I put Granatellie slotted and drilled rotors with Hawk ceramic pads. Cut dust buy around 75%. And a great set up for running Watkins Glenn Road course.
#8 |
I know it was a mustang!
I put Power Stop Z23 Evolution Sport pads on my 2010 SS. Minimal dust and only $100 all four wheels. Had my rotors powder coated (non-braking surface only) to prevent rust...NOT CHEAP! maybe multiple coats of some good Rustoleum would suffice?
2012 ZL1
2010 2SS/RS: Order # NJNJZJ: 2SS/RS, Blk/Blk, MT, Sunroof. 1100 = Preliminary Order: 10/28/08 0000 = Order accidentally deleted by dealer: 3/??/09 ![]() 1100 = Preliminary re-order: 3/??+1/09 3000 = Accepted By Production Control: 5/21/09 3300 = Scheduled For Production: 6/2/09 3400 = Broadcast: 6/4/09 3800 = Produced: 6/17/09 6000 = Delivered To Customer: 7/1/09 R.I.P. = Totaled on 4th day driven in rain: 10/16/20 |
#9 |
Rock Auto has all the OEM stuff you’ll need an typically the best price.
Orange Krush II
#10 |
![]() Drives: 2013 Camaro SS Join Date: Mar 2021
For street driving only, blank rotors like Centric with ceramic pads are a good setup.
