Old 12-10-2020, 11:58 AM   #1
booker3201
Drives: 2010 Camaro SS
Service Stabilitrak message
I just finished replacing my AC evaporator on my 2010 2SS. No warning lights come on when I start up and idle for a couple min. When I back out of my driveway I get the Service Stabilitrak message that goes away and a yellow Car with two wavy lines under it stays lit. I have looked through the forums and checked my Battery connections and all my spark plugs are seated. Car drives fine has good power. Is there a fuse I could check? Looks like a lot of the discussion is about fuse #40 and #43 I think dealing with ABS for the track. The first time I started the car after the fix the TC light came on and stayed on. I re-seated the purple plug for TC and now that does not come on anymore. Any help would be appreciated.
Thanks,
booker3201 is offline   Reply With Quote
Old 12-10-2020, 03:45 PM   #2
booker3201
Took it out for a another drive and now every now and then I am getting some small like ABS type pulsing on the brake pedal.
Old 12-15-2020, 08:54 AM   #3
booker3201
Just wanted to give an update on my Stablitrak issue. I took my Camaro to the dealer yesterday and when they scanned it they found that the Steering wheel position indicator was off a little. They reprogrammed it to use the current setting and my message went away. Hope this helps someone else in the future.
StabiliTrak is an electronic stability control system that uses a steering wheel position sensor to compare the position of the wheel to the vehicle's actual steering response. In the event that something is off, StabiliTrack will make small adjustments to the brake or engine torque to help a driver maintain control
