12-14-2020, 05:27 PM | #1 |
Drives: Velvet Blue Metallic 2015 1SS 1LE Join Date: Apr 2018
1LE front wheel hub part number
Hi Guys.
I apologize if there's now an easy to find answer, but every time I search I get conflicting information. Is the part number for the front wheel hub for a 1LE currently 23103115 or 25954415? The first says "6.2L, without supercharger, with performance pkg.", and the second says "6.2L, with supercharger. 6.2L, without zl1, without performance pkg." Correct me if I'm wrong, but I thought the 1LE and ZL1 had the same front wheel hubs. Is this not true? |
12-14-2020, 06:07 PM | #2 |
Drives: 2014 1le 1SS CRMT Join Date: Apr 2014
25954415 are the ones you want
I replaced all 4 of mine with these ones |
12-15-2020, 11:42 AM | #3 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Very strange , hubs/bearings should last at least 100000 miles . They must have been gotten real supper hot and made the seals fail and loose their grease.
OLD GUY FLYING FAST AND LOW
12-15-2020, 01:36 PM | #4 |
Honestly they were all fine I was just bored during the coronavirus so I took apart my whole rear suspension and did Z06 front 6 piston brakes so I said why not just do everything new
12-15-2020, 02:26 PM | #5 |
Nice upgrade, Chevy should have put the 6 piston Brembo's on the 1LE to start with.
12-15-2020, 02:38 PM | #6 |
12-15-2020, 05:39 PM | #7 | |
Finally bought a dial indicator, took everything off, and found the the driver's side front hub had 8 thousandths of run-out. (You can actually visually see the hub wobble when you spin it.) I'm not sure if it was the sticking piston that did it over time, or just New England roads, but it looks bent at 46K miles. Anyone who has more experience please correct me if I'm wrong, but right now, a bent hub seems like a proper reason for me to buy a new one. |
