Old 12-21-2020, 04:17 PM   #1
bdm14107
Drives: Chevy Camaro 2014
OEM Wheel Paint Color (Midnight Hyper)
I need to repair the curb rash on my 2014 Stock Wheels - Midnight Hyper is the term - I think. Can someone help me with the Dupli-color number for this? Any advice on the process. I've watched all the vids on prep. Do I use a clear coat after painting. Never done this on OEM wheels.
bdm14107 is offline   Reply With Quote
Old 12-21-2020, 04:37 PM   #2
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
They do look clear coated. Mine have a few spots too. You could ask the local body shop for the paint code then ask Duplicolor to give you their code. From what I remember though Duplicolor has the factory code right on the can. I would use higher quality products though. With wheels you also want a hardened clearcoat.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 12-21-2020, 05:05 PM   #3
witenite
witenite's Avatar
Drives: 2010 2SS non RS
Try this for oem code.
https://www.paintscratch.com/
witenite is offline   Reply With Quote
Old 12-21-2020, 11:34 PM   #4
Cyber/Orange10
Cyber/orange10
Cyber/Orange10's Avatar
Drives: 2010 2SS 96 CE LT4, 12 CRUZE ECO
Send a message via AIM to Cyber/Orange10
automotivetouchup.com is good also, will make up cans for you. used them to fix my rims without doing the whole thing. search tire forum for " way to fix you rims..." it tells how to do it step by step. on 08-03-2010
my SS has silver metallic not the Midnight........
Cyber/Orange10 is online now   Reply With Quote
Old 12-21-2020, 11:57 PM   #5
InFiD3ViL
InFiD3ViL's Avatar
Good to know. I have considered ordering from them to do my GFX side skirts and diffuser. I already have a compressor and spray gun.
bdm14107, a 2K clear coat, like Spray Max brand 2K, is also a very good option. That stuff is much more durable and will finish much more glossy (or not depending on the finish purchased) than your normal clear coat in a can, and has a separate chamber with an activated hardener in it. Just make sure to wear a respirator with that stuff, as it has isocyanates in it.
Old 12-22-2020, 09:49 PM   #6
punk5150
punk5150's Avatar
Drives: 2014 SS/RS CRT
The stock SS rims are midnight silver. Once we get past winter I will be repairing/repainting a rim.
Can a shop powder coat a rim with the duplicator paint?
punk5150 is offline   Reply With Quote
Old 12-23-2020, 09:06 AM   #7
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
The 5th gen Camaro 20" wheels were offered in three different finishes. Hyper Silver on cars without RS option. Midnight silver came on cars with RS option. Polished finish could be ordered instead of hyper or midnight silver.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter, SS brake lines ZLI calipers, rotors/pads BMR Trailing & Toe Arms, rear cradle/diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers, HF cats, GMPP axle back, Elite Eng Catch Can, Black ZL1 20x10 & 2011 whls 285/35/20 & 305/35/20 General G-Max RS, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console, hand brake lever, Grant steering whl.
flht99b is offline   Reply With Quote
Old 12-23-2020, 04:41 PM   #8
TheFlyingBananaSS
Mine are blade silver on that chart or as flht99b called it, hyper silver.
oem wheels, paint color
