Old 12-21-2020, 10:48 PM   #1
hunter46554
Drives: 2014 Camaro SS
2014 Camaro SS service power steering
I have a turbo charged 2014 Camaro SS. Changed the AC line on Saturday. Doing so, I unplugged the electrical power steering. Now I get a service power steering message and have no power steering. Any one ever run into this or know a fix for it? I really don't feel like spending 1100 on a new rack & pinion. I can not find any eps motor. Car only has 25,000 miles.
hunter46554 is offline   Reply With Quote
Old 12-23-2020, 05:11 PM   #2
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Check the connection you plugged/unplugged. Maybe bent a prong? Disconnect the battery. See if it will reset..good luck
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 12-28-2020, 03:10 PM   #3
Gabrield
Drives: 2014 Camaro SS manual swap
Any updates?where you able to fix it?
Gabrield is offline   Reply With Quote
Old 01-13-2021, 06:44 PM   #4
hunter46554
Ran codes with a different scanner. Got a code for the Steering Torque sensor. GM does not fix internal rack and pinion problems. I a. Going to be dropping rack & pinion to check the connector going to the steering torque sensor. I will keep posted.
