Old 12-24-2020, 12:30 PM   #1
BlackBird1
Drives: Chevy camaro SS
what is the best handheld tuner out there
Hello,
I have a 2010 Camaro SS 6.2l, the care is 11 years old and I have the extended warranty on it but after this warranty expires Im not getting another one. I had issues with ENDURANCE(MEPCO) of covering things. But anyway What is the best handheld Tuner out there onthe market for these cars.There is no tuner in my area(location) I asked the dealer to do it. because I put in aftermarket part like new coils, plugs and wires new 3 row aluminum radiator, SS lower radiator pipe and 160 degree thomstat. I also install accent dash lighting and a glove box kit kit. In the Spring i Think i will be installing long tube headers and 3' exhaust system with high flow Cats.
I bought the care used with a cold air kit installed and head light changed. The Tuners I was looking at Diablo sport Predator P2 7201 and the Bullydog. Any opinions on which tuner is the best? Thank you in Advance.
BlackBird1 is offline   Reply With Quote
Old 12-24-2020, 01:07 PM   #2
gsxrturbo
Drives: 2010 ss
i liked the sct brand.they can be married to 5 different cars or trucks,just not at the same time.also you can shut off the rear o2 sensors,they even came with a header and intake tune.i have a custom tune now.
gsxrturbo is offline   Reply With Quote
Old 12-24-2020, 04:39 PM   #3
Camaro__ss
Drives: 2013 L99
Another vote for SCT. Dyno Steve (RDP) is a fantastic guy, ships free and fast, no tax and comes with lifetime custom tunes.
Camaro__ss is offline   Reply With Quote
Old 12-29-2020, 04:12 PM   #4
BlackBird1
Thank you so much for the infomation and pointing me in the right direction. I'll read up on your sugestion. Thanks again.
Old 12-30-2020, 12:30 PM   #5
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
This thread should be called "What handheld did you buy before you got smart and switched HPT?"
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
zlathim is offline   Reply With Quote
