#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 12-27-2020, 10:06 AM   #1
srcstc
Drives: 2016 Camaro 2SS
Anybody got a starter diy?
Out of warranty and I'm sure I need a starter.
srcstc is offline   Reply With Quote
Old 12-27-2020, 11:32 PM   #2
goata8
Drives: 2023 LT1 A10
I just did mine. I've heard a few different ways to do it.
After messing around with it for a while I decided to take off the exhaust piece under it. Had to heat the nuts up a little on the exhaust. After that it was basically just shimmying the heat shield out and then the starter. It's tight in there.
2023 LT1, A10, NPP, Tech, Recaros, BVFKQ6 (Ordered 6/24, TPW 7/25, Built 8/1, Picked Up 10/3)
Past: 2017 1SS A8, 1998 SS M6, 1995 Z28 M6
goata8 is offline   Reply With Quote
Old 12-29-2020, 12:20 PM   #3
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
removing the cat is the best way to go and makes it much easier to access. If you have LT's, removing the headers also make it a lot easier.
Sledgehammer70 is offline   Reply With Quote
