![]() Drives: 2011 Camaro SS l99 Join Date: Dec 2018
Installing v6 brakes on a 5th gen SS
Hi I am planning on doing a v6 brake swap on my SS to fit a smaller wheel so far I have the calipers rotors and brake lines from a v6 not sure if I need and anything else then I am looking to install a 16 or 17 inch wheel 10 inches wide but I’m not sure what offset and backspacing I would need to run.
Thanks |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: LT W/2LT,blue metallic Join Date: Jul 2016
not sure what the upside of this would be but if you were closer id swap parts with you.
#3 | |
![]() ![]() Drives: 2018 ZL1 2015 1SS 1LE Join Date: May 2013
Not 100% on all the parts but you will also need the dust shields if you want to do the v6 swap. You can run 16’s with the v6, you need smaller for 15’s and some suspension parts. There are a few companies that sell complete 15” conversion kits.
2018 ZL1 2015 1SS 1LE Stock...ish |
Upside is a smaller wheel, that allows for more side wall on a larger drag tire.
What offset would I need for a 16x9 I’m looking to run a 275 Hoosier or my radial haven’t decided yet
#6 |
Also the SS dust shield won’t work? Can I trim it?
#7 |
Best guess would be a +24et. Not too many choices on 16” wheels though.
#8 |
#9 | |
#10 |
![]() Drives: 2010 2SS/RS Camaro Join Date: Dec 2020
#11 | |
