![]() Drives: 2013 SS RS Camaro 1LE Whipple 2.9 Join Date: Dec 2020
2013 SS LS3 Whipple Injector Oring Leak
Hi Guys,
New to the forum. Our Camaro SS RS 1LE with whipple 2.9L supercharger has a leaking injector Oring on #2 cylinder. The Whipple website said I need to remove the supercharger to replace the orings (recommends all of them). I did get the whipple install manual but I wanted to work out the removal procedure as I don't want to remove more than I need to. Anyone have any info on this and know which orings to order? I have seen varying size info online, even oversize orings, don't want to have to repeat the excersize. Thanks in advance. |
Apologies if this is the wrong forum section to post this issue. Maybe it should be in Forced Induction - V8.
The Whipple 2.9L superchrger & cam was fitted by the previous owner. Don't know what size/brand injectors or rails were installed. See linked photos. https://www.dropbox.com/sh/wsbxisifz..._lfsdseEa?dl=0 |
