12-31-2020, 05:52 PM | #1 |
Drives: 2SS RS ABM A6 Join Date: Jun 2010
LS E85 Dyno Tests
I see this come up all time time -- what kind of power gains will I get with E85.
Here, Richard Holdener will show you, using an LS2 6.0, both N/A and turbocharged. Note: He says this in the video, but just pointing out that (at least on the turbo run), they're not changing the timing. Even more power is made by adjusting the timing for E85. Junkyard Turbo 6.0L LS E85 Fuel Test As a side note, I've recently asked him to do one on gradients of ethanol, since over the years, I've seen people say the best power (for turbos) seems to be about 50-60% ethanol, yet others complain how winterized "E85" is closer to being E50.
Jack Bilger
12-31-2020, 08:16 PM | #2 |
Drives: 11 Camaro SS, Ninja 1000, Santa Fe Join Date: Sep 2020
I have two Dyno runs with my AGP TT setup. The one without e85 is 636.5 and same pull with e85 was 813.8 with (this was true e85 as I paid to drain the 93 octane and add race e85 at the shop). I believe I kept the 93 octane to around 10psi (I was told to run a low boost setting on 93 octane to run conservative. As you can see from the pic that I ran 12.4 psi on e85). I have attached the picture as well. This was on a Mainline hub dyno. This is a net of 177.3 rwhp.
11 Camaro TT SS. 14 1LE motor, full coilover, CNC ported LSA heads, stainless valves, dual springs, Comp 224 cam, Melling oil pump, AGP Garrett GTX30r's, 1400cc injectors, full 3" Magnaflow, dual Walbro 450lph fuel pump, ZL1 6L90 trans, trans cooler, Circle-D 3600, 3.91:1 Eaton Truetrac, line lock, Lingenfelter 2 step. Current boost - e85 814 RWHP.
01-01-2021, 10:32 AM | #3 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Now that is ridiculous! Great info, thanks for the thread and for sharing!
