Old 01-02-2021, 04:11 PM   #1
shu92870
shu92870's Avatar
Drives: 2014 Camaro SS 1LE
NPP Exhaust Db Rating
I cant seem to find an actual answer as to what our
Camaro with NPP exhaust rating is.
Anyone have actual rating?
Or tracked Laguna Seca?
Any problems?
Can I get by with lifting?
I believe its a 90db or 92db day coming up.
shu92870 is offline   Reply With Quote
Old 01-02-2021, 06:58 PM   #2
ariZona28
Give speed a chance
ariZona28's Avatar
I'm facing a similar dilemma with a recently acquired vehicle. The facility in question (AMP, Phoenix metro area) has a limit of 96 DB @ 50ft. I downloaded an APP to my phone so I may attempt my own "sound check" in a few days. You may want to give it a try. I've been told my Z/28 w/NPP will pass with no problem. The Vette I'm playing with is a bit more boisterous!
ariZona28 is online now   Reply With Quote
Old 01-02-2021, 07:43 PM   #3
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
May not answer all of your questions but maybe this will help.
ECS supercharger, Texas speed stage 3 boosted cam, Johnson 2110 race style lifters, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
Old 01-02-2021, 08:14 PM   #4
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Autocross event i went to measured my car at 99db. I had highflow cats and stock headers. NPP valves were open.
They have a 101db maximum
Old 01-02-2021, 08:36 PM   #5
shu92870
shu92870's Avatar
Looks like I’ll definitely have to lift through the mic corner/corners.
Thanks that helps.
Old 01-02-2021, 08:57 PM   #6
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
I’m not familiar with that type of racing, but can’t you put them on a switch and keep them closed for the event. I programmed my NNP to open and close with the garage door buttons.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 01-02-2021, 09:14 PM   #7
shu92870
shu92870's Avatar
1) I pulled my fuse.
2) Your not supposed to run the car with the flaps closed. I don’t want to add a button/controller.
3) Laguna Seca has noise restrictions in place. It’s city owned and it’s an expensive neighborhood. Even though the track was there first.
Old 01-02-2021, 09:28 PM   #8
Southern Comfort
No Tags/Habitual Violator
Southern Comfort's Avatar
Drives: 6.2 Z71
Source?
Southern Comfort is offline   Reply With Quote
Old 01-02-2021, 10:06 PM   #9
Camaro2ss2010
Originally Posted by Southern Comfort View Post
Source?
Google “camaro npp exhaust decibel chart“ and click on images. It should be easily found that way. I have already closed the page or I would give you the link. Sorry
Old 01-02-2021, 10:38 PM   #10
kaba
kaba's Avatar
Drives: 2013 SS LS3, NPP, Blk
Isn't forcing them shut strictly directing the exhaust through the muffler and closing off the more open tips?
1LE Suspension Kit, 1LE Strut Brace, dynosteve tune, K&N Typhoon CAI, Goodridge SS Brake Lines, JLT 2.0 Catch Can, NPP Exhaust Mod
kaba is offline   Reply With Quote
Old 01-03-2021, 06:19 AM   #11
Southern Comfort
Drives: 6.2 Z71
This looks like it.
https://www.mishimoto.com/engineerin...4-sound-check/
Google also returned a link to a mathematical formula for predicting sound level differences at different distances.
Old 01-03-2021, 08:58 AM   #12
JD555
JD555's Avatar
Drives: 2014 2SS RS, 6 sp man
That is like saying you cant run the car with a muffler. Where did you hear that? Its certainly isn't in the manual or they would give a way to keep them open in stock form.
JD555 is offline   Reply With Quote
Old 01-03-2021, 11:42 AM   #13
shu92870
shu92870's Avatar
Flaps run on ecu and open at 3500rpm. I can see if i can find the info.
But 1LE/ZL1/Z28 and i think some 2SS and 1SS had the NPP option.
Opening the exhaust flaps open the back pressure. Trying to run wide open with flaps closed would defeat the whole purpose.
Ill pass on setting up a button to try and hit to close flaps then Hit again to open after mic when running on a track wide open.
I think its an almost full throttle corner. Id rather work on hitting my line and slightly get off gas.
Old 01-03-2021, 01:45 PM   #14
JD555
JD555's Avatar
I have the NPP but its still a muffler and not every SS has them. It will do no harm running closed. I get it it will be open when getting on it but you said you are not supposed to and that is not true. If you are worried wire them close them manually for the run.
