Old 01-02-2021, 10:29 PM   #1
Bfh_american
Drives: 2013 Camaro 2SS
Drag radial (tough one) must read
What’s up guys, I have a question for you.
My Camaro is a 2013 2SS Supercharged pushing 701whp and 620RWT. I’m running stock 20s and Nitto NT555R. I obviously blow them out through first and second on the strip. I was thinking on getting a set of radials. Maybe 17s or what have you but I’m not sure what I can fit and what I would have to do to run these? I’m on stock axles. Only mods are: motor and suspension. I’m running BMR lowering springs as well. 1.25” so I know that’ll be an issue with fitment. I just don’t want to buy the wrong thing. Thanks in advance.
Novi 1500 Supercharger
Meth injection
Kooks off-road headers 1 7/8
Borla atak
BTR Stage 3 cam
All installed by East Coast super chargers
Bfh_american is offline   Reply With Quote
Old 01-02-2021, 10:51 PM   #2
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
I ran Nitto drag radials last year. 20psi. Hooked great at Atco. 305/35/20.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 01-03-2021, 01:38 PM   #3
RankSS
Drives: 2010 Camaro SS
If you do get it to hook those axles are not going to hold. The diff is next. Not trying to be the bearer of bad news but I would upgrade the driveline before the tires.
By selling the stock SS diff and axles before they break you can save some dollars.
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
RankSS is offline   Reply With Quote
Old 01-03-2021, 01:49 PM   #4
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Nittos are terrible for the drag strip but good for wear on the street.
Get some 18" Mickey Thompsons or 17" if you can get the right wheels to clear Brembos.
Old 01-04-2021, 01:13 AM   #5
Bfh_american
I won’t be at the track more than 2-3x a year. Car is a weekend or to and from the gym. Nothing crazy so I doubt the axles will go. They 100% would if I was dragging and hooking them repeatedly. I should have put that up there, sorry about that.
Yes, the nittos have been trash thus far, I’m not going to lie. They’re meh on the street, no issues really except I have to feather it in first and second. I’ve even fishtailed at 80. Good for daily driving but they can’t handle the power.
If I do drop to a 17 or 18”, will I have to do anything or can I just throw them on, go to the track and then swap back?
Old 01-04-2021, 08:19 AM   #6
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
You can, just make sure your tire heights are within 1 inch of each other when swapping for the track, so the ABS doesn't freak out and the speedo is correct. Ok, technically the fronts and rears have to be within an inch, but if going with a drag setup you're going to swap in and out, just get whatever tire height you are tuned on.
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 01-13-2021, 10:38 PM   #7
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Can drop to 17s or 18s, will need to tie back the e brake cable line.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 01-15-2021, 09:23 PM   #8
Vegas Bound
Drives: 2013 Sparkly Red One
18s - no problem. Zip tie the e-brake cable on both sides for clearance.
17s - you may need BMR adjustable LCAs, as you are lowered, I did. Also, tie back the e-brake cables. Weld 17x10 wheels are the best fir. MT ET Street R 305/45x17 are the best tires. Get ready to replace your axles and diff with ZL1 parts.
Vegas Bound is offline   Reply With Quote
Old 01-16-2021, 10:51 AM   #9
Bfh_american
Thanks guys. I appreciate the advice. I was thinking 18s and the MT 305s as well. I’m glad I don’t have to do any insane work for this set up as I figured.
Old 01-18-2021, 08:27 AM   #10
fleebag
fleebag's Avatar
Drives: Moneypit
I had the 18x10.5 rears with the MT et 305’s for a bit. Sadly, I needed some cash so I sold them. They hook on the street fairly well. However, I don’t really go from a dig. As I have to wait until 70-80 to hook
The problem For me with the 17’s is tall tire options. There isn’t many choices above 28”. But that’s because I need less gear due to the turbos.
With your supercharge setup, certain it’s a lot easier to get into boost.
fleebag is offline   Reply With Quote
Old 01-18-2021, 09:26 AM   #11
Bfh_american
Yeah without a doubt easier. The meth kicks in at 3k rpm and then I start losing traction. My main issue is because I’m lowered I’m worried that I won’t fit thicker tires, esp 17”
