Old 01-04-2021, 12:13 AM   #1
2015JRAMZSS
Drives: 2015 Chevrolet Camaro 1Ss
Leaking Differential 15 Camaro Ss M6
So My Differential Has Been Leaking, I recently Took It To Some Guy So He Can Change The Posi, Does It Look Like I Have To Torque Those Bolts Where They Are Leaking From Seems Like Its Leaking From The Drain Plug Also Im Confused Im Not Sure If Those Are The Exact Places where its leaking from. Does anyone Know The Torque Specs For Those Bolts, Do I Need A New Gasket? Hopefully i dont Have To Drop The Diff Again. anything helps guys thank you sorry for sounding stupid i dont know much.
2015JRAMZSS is offline   Reply With Quote
Old 01-04-2021, 09:23 AM   #2
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
check the axle seals...
Good luck!
PEACE
Old 01-04-2021, 02:13 PM   #3
ariZona28
Give speed a chance
ariZona28's Avatar
Clean it off real good with alcohol or brake cleaner, good rag wipe-down. Drive for a day or two then at night (or dark garage) hit it with a black light. I got this "scorpion finder" at Home Depot. Should be able to pinpoint leak. Since maintenance was just done I would double check the area worked.
ariZona28 is offline   Reply With Quote
