01-04-2021, 10:26 PM | #1 |
Drives: 2013 2ss Join Date: Aug 2014
Car on jackstands, engine running, tranmission in gear
Any reason not to do this? It can be handy at times for testing, troubleshooting, etc.
I am hesitant because I am not sure about letting the rear suspension sag with power going to the wheels. I have done this with a solid rear axle and jackstands below the axle housing (suspension loaded). Worked great. Not so sure about the camaro with IRS and the suspension unloaded. So, what do you think? |
01-05-2021, 01:32 AM | #2 |
Drives: 2013 L99 Join Date: Jan 2019
I did it trying to isolate the source of a rear end howling noise. I don’t think you can hurt anything, unless you get your face between the tire and the fender.
01-05-2021, 06:11 AM | #3 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
It'll throw a bunch of warning lights but they'll go away as soon as you drive down the street.
Sent from my Pixel XL using Tapatalk
01-05-2021, 07:24 AM | #4 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
not sure the CVs like those angles so be careful. Taking the rear tires off will help.
2010 SS - Kind of an On3 kit, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
01-05-2021, 07:56 AM | #5 | |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
Proceed with caution! (IMO)
01-05-2021, 08:20 AM | #6 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Not Harbor Freight Jack stands I hope
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
01-05-2021, 09:00 AM | #7 |
Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
Oh come on. Where is your sence of adventure?
01-05-2021, 09:08 AM | #8 |
Drives: 2010 1SS Join Date: Aug 2015
2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
01-05-2021, 10:09 AM | #9 |
And the Darwin Award goes to...
01-05-2021, 10:14 AM | #10 |
01-05-2021, 01:17 PM | #11 | |
Drives: 2012 Victory Red LFX Join Date: Dec 2012
2018 SS wheels, red Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, front grille Bowtie delete, painted red rotors and calipers, 1/4 window American Flags, splash guards, AEM dry panel air filter.
01-05-2021, 03:54 PM | #12 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
I've done it many times with front wheel drive vehicles. With good jack stands the danger is minimal. Just build up rpm slowly, and be ready to hit the brakes if you get any bad vibration. As an added safety factor you could do it outside and not pointed at anything.
01-05-2021, 03:57 PM | #13 |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
Ever watch Ferris Buellers Day Off???
UPSTATE C5 MEMBER
01-05-2021, 04:23 PM | #14 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Exactly what I was thinking.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
