Is my starter going bad?
Recently when I try to turn on the car on my 2013 all lights would turn on and a clicking sound would appear but the car won't turn on until I try it again, and in the past few days it'd have to be 3-6 times until it'd turn on.
Same problem happened to me exactly last year and I've changed it but I'm wondering could it be something else messing up my starter? Should I just get another one and replace it before it happens again? I'll try to post a video later on. |
![]() ![]() Drives: 2014 1SS/1LE Join Date: Nov 2015
Have the battery load tested. If it's good, take a look at your grounds to make sure everything is clean and tight.
Sent from my Pixel XL using Tapatalk
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS Join Date: Mar 2014
And if that ^ all looks good try replacing the starter. They do get weaker overtime, i think mine needs to be replaced soon as well
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
