Old 01-15-2021, 12:28 PM   #1
r.qualls72
Drives: 2011 Camaro SS
Fuel pressure problems
I have a 2011 2SS. I was driving it around town the other day & it just died. It would crank over but not start. During this time my fuel gauge went from 1/4 to over full. If I would let it set for a while, it would start back up for a few minutes then die again. I got it home, changed the in tank pump out with a cheap Amazon pump. Car ran fine for a couple miles then started missing & rough idle & would eventually die. Let it set a while & it will fire right back up for a few minutes & repeat the cycle. Not sure if its' the cheap pump I installed or if it might be FPCM or maybe the tank pressure sensor. Don't mind purchasing what I need, just don't want to throw parts at it. As it would idle, then start to run rough, the fuel pressure would drop to 0.
These are the codes I was getting with my Blue Driver code reader.
P0230
P069E
P025A
r.qualls72 is offline   Reply With Quote
Old 01-15-2021, 03:29 PM   #2
granatl
granatl's Avatar
Drives: 2SS RS ABM A6
FPCM sends a pulse width signal (something like the injectors get) to regulate the fuel pressure.
Did you make sure that your cheap pump accepts this or is it a regular on/off pump
Jack Bilger
granatl is offline   Reply With Quote
Old 01-15-2021, 03:39 PM   #3
gtstorey
Did you get the same codes before the pump change?
Old 01-15-2021, 04:32 PM   #4
r.qualls72
I did not make sure about that. I am far from a mechanic. My knowledge is less than limited. I do feel that it is pump related. But hate to spend 300-400 on oem replacement without being more certain.
Old 01-15-2021, 04:37 PM   #5
r.qualls72
These are codes after fuel pump was installed. I did omit P0325 knock code. I believe P0325 is comes on because of running lean when running out of fuel. I didn't have my code reader before I changed the pump. I knew there was a pump issue because the pump wasn't cycling on & the way the fuel gauge read. All codes are after pump was installed.
Old 01-15-2021, 05:12 PM   #6
gtstorey
It wasn't necessarily a pump issue before since the pump running and gauge aren't really connected at the pump end, other than ground. It could be a fuel pump control module issue or a wiring problem.
Old 01-15-2021, 05:29 PM   #7
r.qualls72
Ok, I will look into getting one. Thanks G
Old 01-15-2021, 07:36 PM   #8
gsxrturbo
Drives: 2010 ss
if it was me i would check the fuel pressure at the fuel rail.
gsxrturbo is offline   Reply With Quote
Old 01-18-2021, 04:56 PM   #9
r.qualls72
Fuel pressure at the rail is 58-59 by my guage & my code reader. Then car starts having issues & drops to zero.
