![]() Drives: 2013 ZL1 Join Date: Aug 2015
5th Gen Camaro ZL1 Parts
I have some parts from a 5th Gen Camaro ZL1. Most parts are used but some are new as I decided to go another direction. Would be a great upgrade for an SS.
List of parts/prices below: New Parts: 1. Metco Valve Cover Breather - $55 2. Roto-Fab Windshield Washer Fluid Relocation Kit, with CAI Adapter Hardware - SOLD 3. Kong Performance Griptec 2.55" Pulley with ZPE Hub - $175 4. Kong Performance Stainless Steel Griptec 2.35" Pulley Only (ZPE style) - $170 5. Melling 10295 Oil Pump - SOLD 6. Holley LS Tall Valve Covers, Black - SOLD Used Parts - 15,000miles on them 1. ZL1 Factory Heat Exchanger - SOLD 2. Roto-Fab Carbon Fiber Intake - SOLD 3. ZL1 Front Sway Bar and End Links - $100 4. ZL1 LSA Factory Camshaft - $100 5. Factory LSA Supercharger Water Inlet Manifold - $50 6. Factory LSA Throttle Body - $215 7. Factory LSA Fuel Rails - SOLD 8. ZL1 Fuel Pump - $175 9. Factory LSA Supercharger Coolant Lines - SOLD 10. Factory LSA Oil Pump - $50 11. DSX Auxiliary Fuel System (need fuel tank adapter, includes tap and die) - SOLD 12. Factory LSA Fuel Injectors (need new supply side O-rings) - SOLD 13. Factory ZL1 Intake - $100 Last edited by JSCoop91; 01-28-2021 at 07:13 AM. Reason: Marked items as sold |
![]() ![]() ![]() Drives: 2013 zl1 vert Join Date: Dec 2018
Payment sent for the dsx kit. Thanks coop.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
![]() Drives: 2010 ss camaro Join Date: Dec 2017
Do you have a ZL1 diff for sale
#6 |
![]() Drives: 2013 camaro 2ss Join Date: Oct 2020
Are the intake manifold Nd pulleys still available? Would I be able to put them in my 13 2ss 6mt? Thanks
#7 | |
The water manifold and pulleys are specific to the LSA supercharger, so it wont work for your SS. Both are still available |
#8 |
SOLD
| Tags |
| dsx, kong, lsa, roto-fab, zl1 |
