01-19-2021, 01:57 PM | #1 |
Drives: 2014 2SS/RS Join Date: Jan 2018
Axle play?
Noticed I have a diff leak on the garage floor. Threw the car up on a lift and found that the fluid is coming out around one of the axles. Obviously the seal is trashed BUT how much play should that axle have with a trashed seal? I can move it up and down a bit. The other side is solid as a rock.
http://cloud.tapatalk.com/s/60075cd2..._115938568.mp4
2014 2SS/RS LS3/M6
01-20-2021, 08:02 AM | #2 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Can't access the video but I guess it depends on how you define "a bit". Definitely shouldn't be much (of course that depends on how I define "much"). Drain the fluid and see how much metal is in it.
01-25-2021, 09:03 AM | #3 |
Just a quick update. No metal in the case. Changed the seal and then the fluid. All is good. The play I was seeing was on both sides equally once i took it out of gear and had the brake off.
2014 2SS/RS LS3/M6
