01-23-2021, 11:08 AM | #1 |
Drives: Camaro 2014 Join Date: Jun 2019
How to remove 3.5mm aux port
Long story short, half the end of my aux cord is stuck inside the input jack, so I'm unable to use the aux port..
How do you remove the aux port? does it pop out, or do I need to take a part the whole arm rest? My aux port jack is non-usb, if anyone has link to replacement part Thanks, - 2014 Camaro |
01-23-2021, 05:07 PM | #2 |
Drives: 14 Camaro LS Join Date: Apr 2017
If you pull off the lower side pieces of the console, you can get to the set of screws that hold the very rear of the console on. Behind that cover is the back of the aux port. You have to push 2 clips down and push it into the compartment.
Sent from my SM-G950U using Tapatalk |
01-30-2021, 11:10 AM | #3 |
