Old 01-24-2021, 02:37 PM   #1
eLeSthree
Drives: 2011 Camaro SS 6sp
Which front coilovers for drag racing?
I have the bmr rear drag kit with strange DAs. 15inch conversion. But still stock up front.
I was leaning towards going with the strange DAs up front as well.
Would that be a good choice?
Which spring would you run with an iron dart block?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 01-24-2021, 04:56 PM   #2
saluki
Drives: 2017 Silverado
If you are willing to spend some money go for santhuffs or menscers if they make a front setup specifically for a 5th gen by now otherwise just go for a standard set of AFCO or Strange
'14 2SS A6, CAI, 2" TSP Headers and tune: SOLD
'13 SS @ Burkhart Chassis
saluki is offline   Reply With Quote
Old 01-25-2021, 06:29 AM   #3
eLeSthree
Thanks for the suggestions. After looking up those manufacturers, it looks like I'm already shopping on the less expensive side of the market. That's usually not a good thing...
I already picked up a new set of 125# springs that work with the strange struts. I guess I'll give them a shot...
1158whp 1017wtq.
630whp 658wtq
Old 01-25-2021, 09:47 AM   #4
saluki
They're definitely not cheap but if you wanna go fast on radials they know what they're doing.
Old 02-23-2021, 01:32 AM   #5
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Look into afterworks as well. I had them build my set. Came with a dyno sheet and starting point for them for my setup. They were pretty damn close out of the box.
ttshovel is offline   Reply With Quote
Old 02-23-2021, 08:07 AM   #6
Vegas Bound
Drives: 2013 Sparkly Red One
I've been running BC Racing Type BR for over 8 years.
Vegas Bound is offline   Reply With Quote
Old 02-23-2021, 08:00 PM   #7
JMI
JMI's Avatar
Drives: Red Jewel Camaro SS
I have the Vikings all around.Lots of adjustments. So far,I'm very happy with them.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
JMI is offline   Reply With Quote
Old 02-23-2021, 10:34 PM   #8
Tajefe Couple
Tajefe Couple's Avatar
Drives: Never just fly under the radar
Not trying to hijack the OPs thread but curious how you have yours adjusted if you don't mind sharing? Changed mine several times and didn't really notice much difference in any runs.
Old Skool
Tajefe Couple is offline   Reply With Quote
Old 02-24-2021, 08:41 AM   #9
Vegas Bound
Bias ply tires: front were 5 from hard, rear were 5 from soft.
Radial tires: front are 5 from soft, rear are 5 from hard.
Also removed front sway bar and have rear sway bar set at stiffest setting.
Old 02-24-2021, 07:36 PM   #10
Tajefe Couple
Thanks Vegas I keep meaning to ditch that front sway bar.
Old Skool
Old 03-18-2021, 09:35 AM   #11
eLeSthree
I should have asked for a ship date while I was shopping around. I would have paid more for a better set, if I knew I'd have to wait over 6 weeks for Strange.
1158whp 1017wtq.
630whp 658wtq
Old 03-20-2021, 08:10 PM   #12
gsxrturbo
Drives: 2010 ss
Qa1 front and rear
2 way adjustable coilovers
gsxrturbo is offline   Reply With Quote
