Old 01-25-2021, 11:25 AM   #1
Crazych66
Crazych66's Avatar
Drives: '12 Camaro 2SS/RS Vert
Question FE3 struts/shocks vs FE4
Hi, I have a 2012 SS vert with the FE3 suspension. I'm in process of upgrading my rear sway bar and end links to the ZL1/1LE bar. Future plans include lowering springs (~1"). I'd like to tighten things up some; however, I'd like to maintain some modicum of ride comfort because even with headers and axle back I will never be able to drown out the complaints from the wife from a stiff ride.
Understand the FE4 suspension is better all around. The question is: Is there a difference between FE3 struts/shocks and the FE4? I see there is a part number difference. If so, is it worth it to change them out? I considered the 1LE struts/shocks but from what I've read, there is a significant difference in ride comfort. The budget doesn't call for more expensive options.
Thanks!
2012 Camaro SS Convertible: 2SS, LS3, M6, Triple Black. Mods: LSA S/C, FIC 1000 injectors, ZL1 fuel pump, Solo Axleback, 1LE FE6 rear swaybar, CAGS delete, Vararam CAI, Heritage grill, Hotchkis springs, '15 FE4 struts/shocks, ZL1 side rockers, Velgen Classic5 wheels, Pedders radius rod bushings, ARH LTHs, gutted HFCs,...
Crazych66 is offline   Reply With Quote
Old 01-25-2021, 01:53 PM   #2
Pearlj10
Drives: 2011 Camaro 2LT
Yes, according to Justice Pete, an expert who no longer frequents this forum, the valving changes from F3 to F4 shocks were significant, both in terms of ride quality and performance. Consider upgrading the rear shock mounts when you add springs. The 1LE mounts are much better and get the shock working quicker. You can use the mounts with F4 shocks if you go that route.
Pearlj10 is offline   Reply With Quote
Old 01-25-2021, 04:37 PM   #3
Avenging Orange
Avenging Orange's Avatar
I upgraded to the fe4 dampers front/rear. They are significantly improved without affecting ride comfort.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 01-25-2021, 05:51 PM   #4
Crazych66
Crazych66's Avatar
Great thanks!
Old 01-25-2021, 05:52 PM   #5
Crazych66
Crazych66's Avatar
Thanks been reading his old posts and didn’t see anything about the shock changes. Looks like I’ll be upgrading them! Thanks for the tip on the mounts!
Old 01-28-2021, 01:01 PM   #6
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
1le shocks are monotube and are designed to work with the stock springs. Not sure non-1le FE4 shocks are any different than the FE3 pieces.
Old 01-30-2021, 11:38 AM   #7
Crazych66
Crazych66's Avatar
Interesting. What I do know is that the part numbers are different, which would lead me to believe there have been some changes from FE3 to FE4.
Old 01-30-2021, 02:14 PM   #8
Pearlj10
Justice Pete said the FE4 bar geometry and revised shock dampening were the highlights of the revised suspension. Here’s his specific words on the FE4 shocks:
The new 5th Gen suspension will will have greater control with a revised bound and rebound map. That control will reduce overall suspension travel. or in short hand, less float.
From this thread:
https://www.camaro5.com/forums/showt...=157292&page=3
I definitely noticed a difference in valving when switching to FE4 shocks. Definitely firmer imho.
Old 01-30-2021, 03:56 PM   #9
Crazych66
Crazych66's Avatar
From this thread:
Thanks again! Justice Pete is the suspension guru and provides further evidence that there is some positive change with the FE4 dampers.
