Old 12-31-2009, 06:15 PM   #1
Anthony @ LG Motorsports
Drives: 1994 1LE / 2006 Z51 Corvette
**LG LS3 Stroker Dyno Numbers 540/537 RWHP/RWTQ**
4" Crank
4.060 bore
Stock ported LS3 manifold
Stock LS3 heads
G6x3 cam
Longtube headers
11.5:1 CR
6spd manual
Pump gas
Notice the torque at 1600 RPM..
Anthony @ LG Motorsports is offline   Reply With Quote
Old 12-31-2009, 06:24 PM   #2
SC_Titan
Drives: TJ
nice curve..
What do you think OrangechevyII's car would do with a 4" crank in it??
SC_Titan is offline   Reply With Quote
Old 12-31-2009, 06:28 PM   #3
Originally Posted by SC_Titan View Post
nice curve..
Typically speaking going to a stroker does not do so much for HP as it does torque. I would think he would be running very close to the same however.
Old 12-31-2009, 06:31 PM   #4
SC_Titan
Drives: TJ
I was thinking the ported heads on his car might shine with more cubes.
anyway, you guys build some nice rides...very solid numbers
Old 12-31-2009, 06:35 PM   #5
Andro
NOICE!!! ™
Andro's Avatar
Drives: Force Fed 427
Nice numbers
Old 01-01-2010, 06:03 AM   #6
PoleCat2SSRS2010
R6P Marketing Lab Rat
PoleCat2SSRS2010's Avatar
Drives: sometimes
How is the long term oil control and ring/piston life with the 4.00 stroke? (related to rod:stroke ratio)
PoleCat2SSRS2010 is offline   Reply With Quote
Old 01-02-2010, 10:08 AM   #7
Louis @ LG Motorsports
Drives: 2010 SS/RS 2009 CG Z06
10 years ago piston/skirt design were not what they are today. Oil control on big cubic inch engines isnt an issue, especially with LS7s coming in factory cars and going 10k miles before oil changes.
Louis @ LG Motorsports is offline   Reply With Quote
Old 01-02-2010, 03:42 PM   #8
MKS
Drives: SS
impressive thats a 418ci?
MKS is offline   Reply With Quote
Old 01-03-2010, 11:38 AM   #9
415~ cubic inch. If you round up, its 416
Old 01-03-2010, 12:31 PM   #10
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
louis, do you have any A6 camaro strokers if so what kind of power are they making?
94guy is offline   Reply With Quote
Old 01-03-2010, 12:47 PM   #11
Negative, we do not at this time. I will surely post the results when we do one!
Old 01-03-2010, 01:07 PM   #12
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
i have an a6 stroker, no dyno numbers but it runs great, about 5000 miles with no issues, more parts waiting to go on when it comes out of winter storage
Old 01-03-2010, 01:16 PM   #13
klatterblast
klatterblast's Avatar
Drives: 2010 camaro 2ssrs blk.
2010 Hennessey HPE650 2SSRS Blk/Blk
Magnuson TVS2300,ported heads,cam,Hotchkis suspension. Weld 17”s, Mickey Thompson’s.
klatterblast is offline   Reply With Quote
Old 01-03-2010, 04:27 PM   #14
MKS
Drives: SS
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 10:40 AM
V6 Camaro Dyno numbers are in!! MadMaxx Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 145 10-07-2009 06:38 PM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 06:02 PM
402 Stroker LS3 with FI? 91Z28350 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 06-13-2009 01:39 AM
C6 LS3 Stock Dyno Numbers TomServo Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 01-22-2009 09:51 AM
