Old 01-28-2021, 08:43 AM   #1
Lacpac
Lacpac's Avatar
Drives: 2012 Crystal Red Tintcoat RS
Cold Weather, warm up car or not
Most of what I read today says to only let a car warm up 30 seconds, enough time to circulate oil, then you can go. So why buy a remote start? I've heard with turbo charged cars its more important to warm up the car before you drive. Any mechanical justification for warming up vs not warming up?
Lacpac is offline   Reply With Quote
Old 01-28-2021, 09:23 AM   #2
gtstorey
The remote start is for getting the car warm for the driver not for the mechanicals (and maybe to defrost windows). I believe it's best for the car to pretty much start driving it immediately after starting, but taking it very easy when it's real cold until it's up to temperature.
Old 01-28-2021, 09:31 AM   #3
BuddyLee
BuddyLee's Avatar
Drives: 2013 Camaro 2SS/RS
You are probably right for the turbo car. I was instructed to let the oil cycle through the turbo but more after driving the car rather than starting the car. I let the engine idle for a minute when I come to a stop for that reason. Turbocharged engines need to cool down before turned off. ... That is sufficient for the engine oil to cool to a level that will not damage the turbocharger bearings.
BuddyLee is offline   Reply With Quote
Old 01-28-2021, 10:00 AM   #4
PaulsSS
Drives: 15SS Camaro
I always warm up the engine for a few mins before moving the cars. I figure it can't hurt anything and it lets the engine warm up a bit.
PaulsSS is offline   Reply With Quote
Old 01-28-2021, 10:02 AM   #5
granatl
granatl's Avatar
Drives: 2SS RS ABM A6
The car's computer handles cold starts and the subsequent warm-up versus decades ago when the driver had to do it. I seem to recall that it has RPM limits if the engine is very cold to protect it.
Jack Bilger
granatl is offline   Reply With Quote
Old 01-28-2021, 10:04 AM   #6
gtstorey
The theory behind not warming up extensively is that the motor is not moving much oil cold at idle. The oil will circulate more and warm up faster with some rpm.
Old 01-28-2021, 10:42 AM   #7
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
This procedure is correct. I start the engine and wait 30 seconds. until the engine is lubricated without load, and then allow the engine to warm up to operating temperatures by driving slowly. Approximately 3000 rpm.
The point is that with a cold start in "choke" mode, more fuel goes into the cylinders, which can disrupt the oil film. Not to mention the E85. Alcohol is simply a degreaser.
And of course the engine is not warm when the water temperature shows you the value of the operating temperature.
You only have a warm engine after the oil has warmed up to operating temperature.
The remote start is for the driver's comfort in cold weather or to scare people
George-CZ is offline   Reply With Quote
Old 01-28-2021, 10:46 AM   #8
xstuntman
Drives: 2012 Victory Red LFX
Modern synthetic gives you instant oil pressure unlike the old dino oil. I still remember back in the jurassic period (80s?) when i swapped from dino to synthetic and was shocked to see almost instantaneous oil pressure on my trucks gauge in the middle of winter. Magic in a bottle at the time. Between synthetic and computer controlled fuel injection warmups aren't really needed. Wish i could say the same about my old Suburbans Edelbrock 1406 equipped 350.
I let mine warm up to the point the rpms drop and then put it in gear.
'18 SS wheels, colored matched Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, victory red rotors and calipers, 1/4 window American flags, splash guards, AEM dry panel air filter, Hot Wheels steering wheel and seat covers, Hot Wheels exterior emblems.
xstuntman is offline   Reply With Quote
Old 01-28-2021, 11:04 AM   #9
Vegas Bound
Drives: 2013 Sparkly Red One
Not true with multi-grade oil.
Vegas Bound is offline   Reply With Quote
Old 01-28-2021, 11:31 AM   #10
CAMARO_HEAVEN
Big John
CAMARO_HEAVEN's Avatar
Drives: Wife 2013 Camaro 2SSRS / ME?
With an automatic vehicle i let it warm up for a couple minutes to let the transmission fluid to get up to pressure.
Many years ago a transmission repair buddy of mine told me that and I do it with all my auto vehicles.
CAMARO_HEAVEN is offline   Reply With Quote
Old 01-28-2021, 11:56 AM   #11
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
I allow my car to warm up first usually about 5 minutes before driving if it's really cold. I do not drive aggressive until the oil temp is at operating temps. Likewise engine coolant and blower oil. I want maximum performance from all fluids which helps longevity of the engine. Remote start is for comfort only although it is used for fun at times
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 01-28-2021, 02:48 PM   #12
BehindBlueI's
Drives: 2011 Camaro SS
True if running dino oil, which could sit in the hot turbo and coke. Coke build up encourages more coking until things get plugged or pieces break loose and lodge, causing reduced flow. Sort of the automotive equivalent of plaque in the blood vessels leading to a stroke. Synthetic oil doesn't coke so it's much less of a concern.
BehindBlueI's is offline   Reply With Quote
Old 01-28-2021, 03:15 PM   #13
ADVMax
Sporting Foole
ADVMax's Avatar
I fire mine and wait for the fast idle to come down, usually 30 seconds or so? I haven’t timed it.
I’m in Alabama so “cold start” is kinda relative to where you are. It gets cold but not minus zero cold.
ADVMax is offline   Reply With Quote
Old 01-29-2021, 01:36 AM   #14
mikeinmobile
mikeinmobile's Avatar
Drives: 2011 2ss/rs
Here's how I warm my cars up.
mikeinmobile is offline   Reply With Quote
