![]() Drives: 2010 Camaro SS Join Date: Jan 2021
LS3 Cam Questions
Thanks EVERYONE!!!
![]() ![]() ![]() ![]() ![]() Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
So you’re looking for sound as a determining factor? Sound is subjective, but I personally wouldn’t use “sound” as a deciding choice. That’s a TSP stage 1 cam. If the car is being babied, would you even notice the torque?
Here’s the same cam on a vette https://youtu.be/fxLiMfUIN_Q
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
#3 | |
![]() ![]() Drives: 2014 2SS/RS Join Date: Jan 2018
Sent from my SM-N986U using Tapatalk
2014 2SS/RS LS3/M6
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
Before you go digging into a well running engine with only 30K on it why not just do the bolt-ons you mentioned? Headers, cat delete and aggressive mufflers may be all that's required to get what you're after in the decibel department. Throw in some 3.91 gears for added torque multiplication with a good tune to tie everything together and life's good!
#5 | |
![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
#6 |
![]() Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
A cam adds chop, and if he’s looking for chop a stage 1 won’t have a lot. As said above do a stage 3.
Roto-fab big gulp, Nick Williams 102mm TB, Kong X-port LSA, Ported 821 heads, BTR stage 4 V2 pd cam, 416 CI bottom end, original block. TSP 2” long tubes, Corsa ZL-1 catback. Nitrous Outlet 102mm plate kit/100 shot JUST IN CASE. NGK BR7EF plugs with Taylor plug wires. DSX flex fuel kit, DSX aux pump, zl1 in tank. deatchwork 1000cc injectors. B&M deep trans pan, stock 6L90 converter, ZL1 diff 3.23 ratio. GM ground effects, T-Rex upper grill, Z/28 Spoiler, Forgestar F14s, 12” subwoofer, and custom paint matched interior.
#7 |
![]() Drives: '11 Camaro 2SS Blk w orange stripes Join Date: May 2011
CAM
I had a stage 3 BTR cam install done. My speed shop said it was the best one they had seen.
| Tags |
| cam, ls3 5thgen |
