Old 01-29-2021, 11:52 AM   #1
DRC69
DRC69's Avatar
Drives: 2011 2LT/RS
Question 2011 LLT Belt Tensioner?
Hi All,
First post. Just bought a 2011 RS 2LT.
Has anyone replace the tensioner? Looks like just 2 bolts, but is there any precaution before removing?
Idler pulley looks bad.
Any help / info would be great.
Thanks
DRC69 is offline   Reply With Quote
Old 01-29-2021, 05:15 PM   #2
Pearlj10
Drives: 2011 Camaro 2LT
I’d say just be careful not to move the tensioner past it’s built in “stop tab” when releasing the belt. I’ve seen a few of those stop tabs get broken by too much leverage, mainly on aftermarket parts though. You should be able to buy just the tensioner pulley, I think, if the tensioner itself is fine. Make sure there’s no fine cracks in the belt while it’s off. Sometimes it’s hard to get a good look at them when they’re installed. Good luck!
Pearlj10 is offline   Reply With Quote
Old 01-29-2021, 05:22 PM   #3
Pearlj10
Here’s the instructions from the Haynes manual with the LLT picture at far left. Torque spec on the tensioner bolts is only 18 ft-lbs, so go easy on the ratchet.
Old 01-29-2021, 05:23 PM   #4
Pearlj10
Damn upside down tablet pictures!
Old 01-29-2021, 05:26 PM   #5
DRC69
DRC69's Avatar
Drives: 2011 2LT/RS
Great thanks for the help and info.
