Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 02-01-2021, 04:40 PM   #1
joepeinado
joepeinado's Avatar
Drives: 2013 2SS 1LE NPP
oil pan and oil starvation
i have an L99 that I am dropping into my 2nd gen. I am swapping out the L99 oil pan so that i can clear my crossmember. I have turned off the DOD portion on HPTuners but will not be removing it just yet. Since i am removing the 8 quart pan and replacing with a 5.5, will i have starvation issues and run my pan dry if i dont delete the DOD eventhough it wont be working since it is deactivated through HPTuners? I will eventually remove DOD and VVT from it, just dont have the cash to do it at the moment.
any tips are greatly appreciated
2013 2SS 1LE NPP, K&N CAI, Texas Speed LTH/catted pipes, Glowtie, tuned by dynosteve (sold)
joepeinado is offline   Reply With Quote
Old 02-02-2021, 10:51 AM   #2
joepeinado
joepeinado's Avatar
anyone?
Old 05-23-2021, 07:48 AM   #3
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
I don't think you will have any problems with the 5.5 oil pan. I have HV an oil pump in my 78 Camaro and it has never been a problem.
Only a small amount of oil = earlier change due to oil fluid wear.
But if you want to be safe, buy a large-volume Milodon oil pan and it will be O.K.
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune.
George-CZ is offline   Reply With Quote
Old 08-30-2021, 12:55 AM   #4
Zspoiler
Zspoiler
Drives: 1979 Z-28 RS Camaro
I have a 1979 Z-28 with a 377 Supercharged small block chevy.It has a Milodon 7 quart Road race oil pan .Moroso windage tray .And a Melling High volume oil pump .If you have the room. I also have an oil cooler with twin remote filters .This ways to add capacity.if needed
Zspoiler is offline   Reply With Quote
