Old 02-03-2021, 02:56 PM   #1
Att3mpt
Drives: Chevy Camaro 2015 2SS RS
Question Supporting mods for l99 FI?
Hi, I currently have a full Bolt on l99.(no cam) I wish to add a Magnuson heartbeat supercharger soon. what are some supporting mods that'll handle boost more reliability. This is a DD but I would like to be making around 650-700whp reliably.
I do want to keep VVT and only delete DOD (idk if thats possible)
any advice will be appreciated!
Please share part # or link too.
thanks!
Att3mpt is offline   Reply With Quote
Old 02-03-2021, 03:36 PM   #2
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Going to have too upgrade the fuel system pump and injectors. Bigger throttle body to handle all the air that it will want to suck in. Axle and tires to handle all that power to the wheels.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 02-03-2021, 04:21 PM   #3
bayarea408
bayarea408's Avatar
Drives: T
E85, meth, ARP bolt hardware, maybe a multi layer ls9 gasket, Suspension There is alot of suspension.
Transmission, the power levels you want a 6l80E wont live long. So common alternatives will be 4 speed 4l80E, Th400 3 speed, stick shift conversion, or you find a Camaro ZL1 intended 6l90E, most are for trucks.
There are cam kits that keep variable valve timing and delete DOD, GPI makes some, the thing is finding a tuner with enough knowledge to tune it to its maximum efficiency or GPI MIGHT do long distance tunes.
bayarea408 is offline   Reply With Quote
Old 02-03-2021, 04:46 PM   #4
JANNETTYRACING
JANNETTYRACING's Avatar
thanks!
The cam and DOD has to go for that power level.
Cam is worth 100+ of that
ZL-1 pump
JRE fuel pump control module
JMS fuel pump voltage booster
ID1050x injectors
JRE blower cam package
LT headers
Catch can
JRE custom tuning 650 RWHP on pump gas
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 02-03-2021, 07:09 PM   #5
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
I kept VVT. GPI makes a killer cam for this. Your going to need lifters, cam phaser, springs, retainers..... and so on. The power level you want is about $20k if you give it to a shop. If you DIY it you might get away with $15k. It's best to set a budget and then find out what you can do within that budget.
Remember the more power you want, the more stuff you need to get.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 02-03-2021, 09:59 PM   #6
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
thanks!
To do this right it will be expensive. Im amazed at how much money ive spent just getting to where i am now. Im about to dive back into forced induction here soon. Expecting another 15k and i have most of the supporting mods already. This crap isnt cheap lol. It takes a really good job and a very understanding wife haha
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 02-04-2021, 08:47 AM   #7
RupertPupkin
Drives: 2014 Camaro SS 1Le
OP—— Send it!
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 02-04-2021, 11:26 AM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yea, it will be expensive!! One of my buds just did a Whipple Stage 3 kit from Redline Motorsports here in Fl and it was an M6 car and he spent 18k fo do it, but he did get 683rwhp out of it!! The L99's will be a bit more as you have to consider a stall converter and a trans cooler too. I was going to go FI, but decided to stay NA as my "extra money" has gone away for that. lol. Good luck in your search and build.
Old 02-07-2021, 03:55 AM   #9
Att3mpt
ok thanks ya fuel system might be the first
Old 02-07-2021, 03:57 AM   #10
Att3mpt
ZL-1 pump
ID1050x injectors
LT headers
Catch can
Ted.
Hi Thanks for the reply!
I assume VVT will be gone as well?
Old 02-07-2021, 04:01 AM   #11
Att3mpt
Would It be smarter to get the supporting mods first before doing any FI?
Fuel Pump seems to be the highest priority.
Old 02-07-2021, 09:09 AM   #12
IKILLEDSUPERMAN_ZL1
Drives: 2011 Camaro SS
I did my car in stages. I did the stall and tranny cooler first. Then the rear suspension with the fuel pump since cradle was coming down. Then the cam and Vvt and DOD delete with the turbo install. I dont want to add it all up lol.
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
IKILLEDSUPERMAN_ZL1 is offline   Reply With Quote
Old 02-07-2021, 09:19 AM   #13
RupertPupkin
If you can afford it all in 1 shot do it all at once.
730whp: 630Trq
Old 02-07-2021, 10:12 AM   #14
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
Yes, I think so. After building up the drivetrain and suspension to handle the power, You might just find out that these cars are pretty freakin quick and not want to go fi. Not talking you out of it (just did it myself too) but I will admit to almost building it off the road- can’t really do much with a drag setup on the street.
joshnmn is offline   Reply With Quote
fuel injector, l99 engine, magnuson heartbeat, super charger kit, vvt
