02-04-2021, 07:34 PM | #1 |
Drives: '23 LT1 A10 Join Date: Oct 2015
What to use to monitor transmission temps?
I have tried handheld OBD2 scanner and a bluetooth OBD2 using Torque and OBDLink. None of them show the PID for transmission temp. Suggestions?
02-04-2021, 08:41 PM | #2 |
Drives: 2010 2SS/RS LS3 A6 IOM Join Date: May 2013
My 2SS/RS has a trans temp gauge, maybe you can make the mod
02-04-2021, 10:20 PM | #3 |
02-05-2021, 07:06 AM | #4 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Not sure the factory 4 pack gauges are 100% accurate like the engine oil temp gauge.
Orange Krush II
02-05-2021, 10:22 AM | #5 |
I have apiller mounted Aeroforce dual gauges and 1 of the parameters I have showing is the trans temp, and the 4 gauge cluster trans gauge is off by about 10-20 degrees. So it seems on mine.
02-05-2021, 12:02 PM | #6 |
Happen to have a model number for your gauge?
24 LT1 M6 Sharkskin Metallic
14 Mazda Mazda3 S Grand Touring (Daily) |
02-05-2021, 03:40 PM | #7 |
Well did some driving around today under different circumstances and paid attention closer to what my trans temp gauges were showing, the console gauge would show 180 straight up, but my Aeroforce would show anywhere between 165-180. The console gauge would move to the right of 180 just barely when the trans temp said 188-190. So quite a bit of temp difference there. When I cruise around at speed for quite a while the console gauge would move to the left of 180, just barely and my Aeroforce would show 145-150.
Here is the model I have in my Camaro. https://www.phastekperformance.com/D...-gauge-cn2.htm
02-05-2021, 03:47 PM | #8 | |
02-05-2021, 04:55 PM | #9 |
You are welcome sir!! Yea, it just plugs into the OBD port and I got the 2 gauge pillar pod from the guy I got the gauges from, but Phastek has them as well... Yea if someone asks a question about something I can help with, I will do my best to get them the answer they need and some facts to back it up. Good luck, oh and those Aeroforce gauges can show A LOT of parameters, you just need to program in what you want to see by scrolling thru them. I have mine set to show 4 different parameters for each gauge.
02-05-2021, 10:36 PM | #10 | |
