Old 02-05-2021, 12:43 AM   #1
67-LS1
67-LS1's Avatar
Drives: 1966 Chevelle
LFX in a 1966 Chevelle
I’m going to post some pics of my project to take an LFX V6 and a 6 speed auto from a wrecked 2013 Camaro and install them in my 1966 Chevelle.
The Camaro had 525 miles on it when it was wrecked so the engine was almost new. I got the engine, transmission, engine wire harness and the ECM. It shipped to me on the front subframe from the Camaro.
The car had the original 283/Powerglide. I bought it from the second owner.
I removed the engine and test fit the LFX. No dice. So I decided to lift the body off to modify the frame. I also decided at this point go with Hotchkis suspension and Wilwood brakes.
66 Chevelle with 2013 LFX V6, 6 speed auto, full Hotchkis suspension, Wilwood 4 wheel discs.
67-LS1 is offline   Reply With Quote
Old 02-05-2021, 12:53 AM   #2
67-LS1
67-LS1's Avatar
Once the frame was out I started to tr6 to figure out motor mounts. I learned some interesting things.
- One side of the Chevelle frame is 90 degrees from the other side.
- The sides of the LFX engine are parallel to one another.
- This means the sides of the engine are 45 degrees from the frame.
So to make motor mount fabrication easier I built a wooden box to mimic the engine sides. This was a LOT easier than swinging the engine in every 5 minutes.
Old 02-05-2021, 12:58 AM   #3
67-LS1
67-LS1's Avatar
I cut away a big piece of the front K member and reboxed it. I also added a plate across the bottom. I set the engine up high to keep the pan and tranny pan up as high as I could. I knew the car was going to be low.
Old 02-05-2021, 01:06 AM   #4
67-LS1
67-LS1's Avatar
I used wood to make mock-ups of plates to mount to the side of the engine. Once I had them correct I cut them from steel.
I built the motor mounts in place.
You can see how high the engine is from the trans and crossmember photo.
Old 02-05-2021, 01:10 AM   #5
67-LS1
67-LS1's Avatar
Loading up the frame to go to powder coating.
Once it came back I started to assemble the suspension and brakes.
Then back on the ground.
Old 02-05-2021, 01:16 AM   #6
67-LS1
67-LS1's Avatar
Engine going on the frame. The stick down pipes with cats not only cleared both sides but also lined up with the crossmember humps.
I eventually eliminated the second cats. The first cats are still on the car.
Old 02-05-2021, 01:22 AM   #7
67-LS1
67-LS1's Avatar
With the combination of the new trans being gigantic and me mounting it high for more clearance, the trans tunnel was destined for the trash heap.
Old 02-05-2021, 01:25 AM   #8
67-LS1
67-LS1's Avatar
I enlarged the trans tunnel and the driveshaft tunnel but as I’ll show you later, I didn’t go back far enough.
My bad.
Old 02-05-2021, 07:15 AM   #9
Deputy347k9
Deputy347k9's Avatar
Drives: 2014 Ashen Gray Convertible
Truly amazing, you are one talented motor scooter. Love view the progress through you pictures. God really blessed you with a great talent!
Deputy347k9 is offline   Reply With Quote
Old 02-05-2021, 07:18 AM   #10
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Holy crap that’s some talent. That’s gonna be a great reliable cruiser once it’s done.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 02-05-2021, 10:15 AM   #11
67-LS1
67-LS1's Avatar
Once I got the tunnel done I worked on the shifter. I wanted to use a powerglide shifter so I had to make the “throw” match what the trans needed. I attached some graph paper to a workbench and started to work it out.
Once I had it figured, I cut a new detent plate for the shifter, first from wood then metal. It took a few tries...
Old 02-05-2021, 10:18 AM   #12
67-LS1
67-LS1's Avatar
These transmissions don’t use traditional “slip yokes” so I had to use a CV style driveshaft with an adaptor to the stock 3 bolt flange.
Old 02-05-2021, 10:21 AM   #13
67-LS1
67-LS1's Avatar
Now the fun part...
I had a guy mod my harness but I ended up almost completely rebuilding it anyway. He just broke out the wires I needed. I stripped a lot of unused wires from the harness. I also extended the last portion of the harness so I could hide the ECM behind the passenger side headlight.
Old 02-05-2021, 10:29 AM   #14
67-LS1
67-LS1's Avatar
Now the fun part...
Note that I am not running the BCM.
