Old 02-05-2021, 05:59 PM   #1
8driann
Drives: 2012 Camaro SS 45th Anniversary
Lightbulb Nitrous question
So I took out the engine to rebuild it after a spun rod bearing. I was thinking of getting a nitrous system to run a 100 wet shot by summer on everything stock besides a few basic bolt ons. I am in the process of putting back together as we speak but I had a question. If I want to run up to a 200 shot, would gapping the rings for nitrous be enough? If I have the chance to gap them right now might as well, but would it be suitable for daily driving? And is that all I would need for a 200 shot? Or do I still have to upgrade other internals like bottom end or other components? TIA
8driann is offline   Reply With Quote
Old 02-05-2021, 09:35 PM   #2
Bo White
Bo White's Avatar
So your going back with stock rods and pistons?
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 02-07-2021, 10:15 AM   #3
8driann
Basically yes. Thats why I was wondering if to run around 200 shot all I need are gapped piston rings and like plugs? I am going back to stock everything, but most parts are going to be new. Only thing internal that I am keeping stock are piston and rods. Everything else in the block is new but stock.
Old 02-07-2021, 11:27 AM   #4
Bo White
Bo White's Avatar
Gap accordingly
Totalled:
Old 02-07-2021, 06:00 PM   #5
bottletalk
Drives: 15 Camaro 2SS M6
why didn't you go forged? $?
bottletalk is offline   Reply With Quote
Old 02-08-2021, 11:27 AM   #6
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Don't forget fuel. You are potentially surpassing the limits of a stock fuel pump with a 200HP shot.
They say forged internals are suggested at that level, but progressive shots are easier on the engine than instant and you might get away with 200 that way. How pissed will you be if it blows?
Make sure you use a colder plug and pull timing.
Old 02-10-2021, 01:09 AM   #7
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
Gapping should help. But while your in there, I'd at least do pistons. Stock are hypereutectic pistons, so watch for knock. Also, the ringlands are not thick. If your tapping off the fuel rail for the wet system, log your afr and fuel pressure. You may get away with it for the 100 shot, but be cautious about the 200. Be sure to check your plugs. Especially #7. You'll be traction limited, so a progressive system will be helpful.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
200 shot, nitous, nos
