02-07-2021, 12:26 PM | #1 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Truetrac
Finally getting around to finishing up the suspension.....and 3.91's are part of it.
I see the Truetrac upgrade thrown around occasionally. For those that have it, is it worth the money for the garage queen, street driven, spirited driving old guy?
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
02-07-2021, 07:03 PM | #2 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Old guy here with a 2010 SS and I have a Z28 Diff which is a OEM version of the trutrac and you can’t beat it!!!
Orange Krush II
02-08-2021, 12:24 AM | #3 |
'It's an experiment'
TT is a bit noisier but well worth the upgrade. If you have solid diff bushings, you’ll notice it a bit more...
-Don
747 RWHP 794 RWTQ
02-09-2021, 07:37 AM | #4 |
Thank you.
02-09-2021, 07:39 AM | #5 |
Already have a bunch of BMR bushings in the rear, so noise is a given. Appreciate the input.
02-09-2021, 08:02 AM | #6 |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
TT is on my list. I've had a similar units in other vehicles and it is better than a typical posi or locker more consistent and better out of the turns for sure. The noise I experienced was negligible, it can be minimized with the right fluid. I imagine the bushings will make a huge difference in NVH too.
Sent from my SM-N986U using Tapatalk
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
02-09-2021, 09:01 AM | #7 |
Much better than the stock limited slip for sure. I don't have much noise with mine at all, nothing the radio can't hide.
GPI 416 w/Custom GPI Cam, GPI Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
