Old 02-10-2021, 12:12 PM   #1
Camarobychance
Drives: 2014 AGM 2SS RS 1LE
Motor mount DIY HELP!!!!
Attempting to install the bmr motor mounts myself and It was going perfect until now I can seem to get the actual mount and bracket out of the engine compartment. All 4 bolts are off of the bracket and both nuts are off of the mount itself I just can’t seem to wiggle it out of there. I have the engine jacked up using a block of wood and I’m pretty sure I have it maxed out. Am I missing something? What do I do?
Camarobychance is offline   Reply With Quote
Old 02-10-2021, 12:34 PM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
You could try lifting from one side or the other to gain more clearance. You are maxed on lifting the engine when the bellhousing on the trans gets close to the trans tunnel.
I have the Prothane mounts and I don't remember it being that difficult, but I probably had headers at that time.
Sometimes lowering a jack a hair can provide more room. I did mine entirely from under the car.
Old 02-10-2021, 12:51 PM   #3
Tarendor
Tarendor's Avatar
Drives: 2012 camaro 2ss rs L99
Did you separate the mount first from the bracket?
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
Tarendor is offline   Reply With Quote
Old 02-10-2021, 03:03 PM   #4
fz4k98
Drives: 2013 1ss
I had to loosen and remove all bolts and nuts from mount and bracket, jack up engine a little for clearance. Then pull the bracket away from the engine and lift it up as far as possible while lifting and rotating the mount.
They parts are keyed together and to the frame and engine. Gaining clearance by rotating the mount will allow enough clearance to then turn the bracket and remove it.
Clear the 2 keyed parts and rotate mount 90 degrees for clearance. Install is opposite sequence so keep an eye on sequence to remove.
fz4k98 is offline   Reply With Quote
Old 06-13-2021, 10:06 AM   #5
Camaro&Harley_Guy
Drives: 2012 RS/SS
Good to know. I will be installing a set of poly mounts soon on my 2012 SS
Camaro&Harley_Guy is offline   Reply With Quote
Old 06-13-2021, 05:12 PM   #6
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
This right here. I havr bmr on mine and quite honestly, a bit of a pain to install
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 08-07-2021, 02:23 PM   #7
moose517
moose517's Avatar
Drives: 2013 1SS
So figured i'd just pop into this thread as i got my BMR mounts today and want to install them. Is it possible to do this without removing long tube headers? Hoping to tackle it here in a bit but i have a feeling that's gonna be the holdup and I'd rather not if i can help it (I'm on a gravel driveway, don't have anywhere to park it sadly that isn't to work). Seeing good advice though otherwise.
moose517 is offline   Reply With Quote
Old 08-08-2021, 02:11 AM   #8
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
I'm wondering the same thing 🤔
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 08-08-2021, 02:27 AM   #9
AlanRubin
Banned
Drives: 2010 LS
I just did mine, and I had to lift the engine 2" up. I did not even get close to the
tunnel wall.
Loosen the nuts to the trans mount at the trans cross-member first. Don't take the
nuts off, in case the mount studs pop out. Loosen them till the nut head is flush
with the end of the stud.
Driver side was the hardest, with the starter there, and the bare wire if you do not
have the cover. I got some sparks putting the pedestal back in on that side...
SO, I taped it up, and tried again, was okay after that.
AlanRubin is offline   Reply With Quote
Old 08-08-2021, 02:36 AM   #10
morepowerjoe
tunnel wall.
But do you have longtubes?
Old 08-10-2021, 08:10 PM   #11
AlanRubin
Banned
Drives: 2010 LS
Oh, No, and all instructions say you have to remove them, because you may not get the
engine up high enough. Passenger side should be easier, it's the driver side that has
a bigger pedestal. I was okay with the passenger side, then I had to lift the engine
another inch or two to get the driver pedestal out.
Old 08-11-2021, 01:05 PM   #12
moose517
moose517's Avatar
Drives: 2013 1SS
Yeah i decided not worth the trouble not doing so. Course also decided good time to also wrap my headers since like an idiot i didn't do so back when put them on haha.
Old 08-11-2021, 05:34 PM   #13
Tarendor
Tarendor's Avatar
I did it with long tube headers already installed but I cheated after about 5min. LoL
I was able to lift them up and cut off the bottom bolt with my sawzall.
Old 08-11-2021, 06:10 PM   #14
InFiD3ViL
InFiD3ViL's Avatar
Now THAT is how I would do it! I like the way you think.
help me, help please, motor, motor mounts
