NightFuryCamaro
Drives: 2012 Camaro 2SS Join Date: Aug 2019
So recently I have acquired a Whipple 2.9L supercharger. I have a BTR Stage 4 Supercharger cam kit installed to the car already. I've come to understand that the Whipple provided injectors and fuel pump booster won't be enough to keep up with the Cam and Blower working together. I also have Long Tube headers + header back exhaust + high-flow cats. Currently making 470RWHP without the blower, I expect to be nearing 700RWHP with the blower, I'd like a few suggestions on fuel systems, haven't done much of my own research yet and not sure what figures I'm going to need. I plan on breaking 1000 Crank horses in the future as well. Any suggestions?
Follow me on Instagram and TikTok! @NightFuryCamaro
![]() https://www.instagram.com/nightfurycamaro/ https://www.tiktok.com/@nightfurycamaro |
![]() Drives: 2012 Camaro SS Join Date: Jun 2019
I recommend you do the fuel system once if you can, buy the fuel system that's going to get you your 1000hp and install it now with the whipple, even if it's not fully utilized. A ZL1 pump/BAP will get you to around 700hp and are fine to do with your whipple, but not much past that. I'm using the ZL1/BAP with Fast injectors and I'm at 600rwhp.
The popular brands I read on here are usually Fore and DSX for the fuel pumps. ID or Fast for injectors.
2012 Camaro SS LS3, JRE Scoop, CAI intake, Whipple Supercharger, Fast 85lb injectors, ZL1 pump, McLeod RXT clutch, MGW shifter, Stainless Power 1 7/8 headers w/HFC, Ridetech coilovers, BMR sway bars, trailing arms, toe rods, cradle bushing inserts, 2020 Speed Tuned.
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Fore triple pump and at least 1300 injectors if you looking for 4 digit power numbers.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
![]() Drives: 2011 1SS RS Camaro, 1995 LSX 240SX Join Date: Mar 2011
I ran the ZL1 pump and booster to ~750hp but was right on the edge. Upgraded to the Fore Triple from AGP and E85. No issues and continuing to add boost.
2011 Camaro 1SS
Whipple Supercharged 1150/1100 @ 24psi - Removed blower and went Turbo Huron Speed T6 1135/1070 @ 20psi so far. 15 more PSI loading... |
![]() ![]() ![]() ![]() ![]() Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
Another option.. DSX aux pump and whatever injectors. FIC/ID etc. if you have a tuner already, see what injectors he would recommend and what he uses. Last thing you want is a tuner that can’t tune what you bought, leading you to source out multiple tuners..... Ask me how I know. Lol.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
#6 |
![]() ![]() ![]() ![]() Drives: 2010 Camaro (M6) 1000+ HP SBE Join Date: Jun 2011
If you plan to stay with 93 fuel with maybe some meth injection at WOT, then a dual pump set up with 1000cc injectors will handle it. I was running a single pump with an in-line booster pump that came on at WOT, meth injection, and Maggie at max output, with right at 700 hp to the wheels and doing fine. But when I switched to E85 on the maggie then I had to go with the Fore dual pump set up. Then when I put the F-1X on I had to really step up the fuel system as noted in my sig.
Bottom line is if you think you have the HP bug then you probably do and it is much cheaper in the long run to go big in the beginning and leave yourself room to grow. Fuel is one of the essentials and the guys before me are telling you right, so go big my friend and you will thank yourself a couple of years from now when the 700 rwhp is beginning to feel slow (and it will).
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam Brodix BP BR 3 Heads Kooks LT Headers and full 3" exhaust Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears McLeod RXT Twin HD Clutch & Upgraded Slave RPM Level VII TR6060 BMR Drag Suspension Package w/Strange shocks Carlyle 15" and M/T ET Street R radials 10.1 @ 143 mph 1/4 mile |
#7 |
![]() Drives: 2010 Camaro SS2 Join Date: Oct 2020
I have the DSX Aux fuel system with stock pump and am at 700 whp with FIC injectors and I'm fine for fuel delivery right now. Ready to install a ZL1 pump for piece of mind. FYI, I wired in a LED activation light that is on my dash that is wired into the Aux pump so I know when the pump kicks on, (comes on at 1lb of boost) and like others have said, go big so when your 700 whp feels slow (and it will after a while) you have fuel covered when you build for 900 whp
2010 2SS M6, Procharger, 8 rib, 12lbs, E85, Holley intake W/ fuel rails, TSP Blower cam 229/242 w/springs, Harden pushrod, FIC injectors, DSX Aux. fuel, Kooks long tube headers, xpipe, no cats, Mcleod twin disc, G Force Axles, DSS aluminum drive shaft, Detroit Trutrac, LPW dif cover w/BMR bushings, BMR Toe rods and Trailing arms, 5 Stars, M.T. E/T Streets, Hurst short throw, Mighty Mouse catch can, 702 WHP on Mustang Dyno 10.7 1/4 Mile
#8 |
![]() ![]() Drives: 2014 1SS/1LE Join Date: Nov 2015
I am literally installing a flex fuel triple pump setup right now. I'm expecting about 800 at the wheels when I'm done but I probably have enough fuel pump to double that if I decide to in the future. Don't just plan for this build, plan for the next one or two as well.
#9 | |
That guy
James Montigny
2017 Camaro 2SS A8 - Krypton Green Magnuson 2650, TSP Head/Cam, DSX Low Side, Flex Fuel, LT4 HPFP, 103mm TB, Big Gulp. |
#10 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
See signature. If you want more go with dual or triple pump and 1300 injectors right out of the gate and do it once. DSX aux pump can get you there too, but I don't like the idea of drilling into my fuel tank. If you plan to go E85 my setup not recommended. I've read in a few posts the DSX system starts having trouble around 850whp.
#11 | |
Case in point, the Corvette ZR1 that utilizes the LT5 motor. It utilizes both DI and port fuel injection and it makes 755hp (crankshaft, I believe). Check out the 6th Gen Camaro Forum for info specific to your platform. ![]() |
#12 |
I believe the dsx aux kit is advertised as supporting 1000whp for our cars without e85, but from what i've read from people's experience it doesn't seem to.
#13 | |
That guy
My mistake. I drifted in from Camaro6 and didn't even notice. The DSX will suit my needs.
James Montigny
Tags |
btr; stage 4; cam; nightfury;, super charger kit, whipple 2.9 |
