Old 02-19-2021, 02:56 PM   #1
Att3mpt
Drives: Chevy Camaro 2015 2SS RS
Is Air Dam necessary if you have a front splitter?
just as the title said, is there a purpose keeping the air dam once you install the splitter?
Att3mpt is offline   Reply With Quote
Old 02-19-2021, 03:10 PM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Took mine off a looonnnggg time ago. lol... Looked crappy so I removed it and never had any issues..
Old 02-19-2021, 03:16 PM   #3
Att3mpt
lol sounds good, mine was breaking off so I installed a splitter and didn't bother putting it back on
Old 02-19-2021, 03:26 PM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yep, mine was looking tacky so I pulled it off even before I put a splitter on there. Some folks will tell you it is there to deflect air away from the engine compartment under the car, but it is so flimsy I couldn't see that. lol..
Old 02-19-2021, 03:58 PM   #5
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Air dams work at high speeds but most of us will never drive fast enough to need it. Mine came off after a couple years and never bothered putting it back on.
Old 02-19-2021, 04:47 PM   #6
BLU DUCE
BLU DUCE's Avatar
I'm just looking at this as what are you talking about? Is it the rubber piece that runs along the front bottom of the car in the front. I have had mine on since I bought the car and it is still in good shape. I have a splitter on my car from day one. I'm putting a new SLP splitter on. But if I don't need it I'm going to take it off.
THXS
Old 02-19-2021, 06:10 PM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
THXS
Yes sir!! That be the piece we be talking about!!
Old 02-20-2021, 04:41 AM   #8
CPCNY
CPCNY's Avatar
Drives: 2010 2SS/RS, VR ext/Blk Int
THXS
I have the SLP splitter and still have the air dam on.
CPCNY is offline   Reply With Quote
Old 02-20-2021, 06:02 AM   #9
BLU DUCE
BLU DUCE's Avatar
I left it on with my other splitter and never had any problems with it. And like I stated above it is still in good shape. The installation of the SLP splitter shows leaving it hooked up on each end and letting it hang down while installing the splitter. When I get around to installing the splitter I'll make up my mind weather to take it off or just leave it on.
Old 02-20-2021, 07:01 AM   #10
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
I left mine on with the SLP splitter. The front bolts are a pain to get to with it on though. If you have long arms it will help.
ECS supercharger, Texas speed stage 3 boosted cam, Johnson 2110 race style lifters, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
Old 02-20-2021, 07:26 AM   #11
BuddyLee
BuddyLee's Avatar
Drives: 2013 Camaro 2SS/RS
The one on my car acted as an effective snow plow and has ripped off twice in two years. Once by the snow and once by a curb while parking one day. I don't have a splitter for the same reason. For me they are non functional. However, for the Grand Nations there is a plastic intercooler scoop that is most functional but because the GNs ride higher there is no snow scoop issue to be had, in fact where with the Camaro I have ripped two off in two years the GN still has the factory intercooler scoop intact.
BuddyLee is offline   Reply With Quote
Old 02-20-2021, 09:45 AM   #12
jokrz187
jokrz187's Avatar
Drives: 2015 1SS
Nope, pulled that off before I put on the splitter and threw it away. I also do my own oil changes and was tired of that being there and having to lift the car higher just to get under that piece.
Custom TSP Stage 2 Cam/GPI intake Ported Rod Mod /VARARAM CAI/Mishimoto Catch Can/1 LE front & rear sway bars/ engine cover/fuse box custom painted, strut tower brace, Texas Speed LT, Hi Flo Cats, Magnum Tru-X pipe, NGK Spark Plugs, PCM Spark Plug Wire, Painted Calipers, CF Spoiler w/wicker bill.
jokrz187 is offline   Reply With Quote
Old 02-20-2021, 10:41 AM   #13
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
The idea is the less air going under a vehicle, the better the mileage, at least for trucks. When racing, you really want to limit air going under the car as much as possible. On the ZL1, the air dams are only at the corners. If you take it off, you won't notice any difference.
Old 02-20-2021, 10:44 AM   #14
rdavis
Drives: 2012 SS
Took mine off when I installed my slp splitter. Looks better & noticed no difference in anything.
2012 2SS/RS 6speed, Howards asa cam on 113lsa Stainless works LT's, NPP exhaust, Z28 Cai, 3.91 gears. Tuned by Blue Thunder 2 racing Lubbock Texas.
rdavis is offline   Reply With Quote
air dam, install, splitter
