Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Transmission / Driveline
Old 02-21-2021, 07:53 PM   #1
Mkoppes
Drives: 2013 Hot Wheels 2SS
3.91 Differential with Trutrac
This was originally a 3.45 out of my 2013 SS. At 9k miles, I swapped gears to GM 3.91. I replaced all of the bearings and seals while I had it out. Bearings and seals are all AC Delco. I also replaced the LSD with a Detroit Truetrac. I will include the original LSD if interested as there’s nothing wrong with it. I currently have another 11k miles on the gear change. All work was done by myself. I’ve had the car since new. It was never raced, never had slicks or dr’s. Never driven in the winter. There’s NO gear noise. Absolutely nothing wrong with this diff. Oil changed 1000 miles after gear swap and every 3000 after that. I will include two quarts of Torco RGO gear oil and two J44394 Seal Protectors. I found a good deal on a new ZL1 diff is the reason I’m selling this. $1200
Mkoppes is offline   Reply With Quote
Old 02-21-2021, 08:13 PM   #2
Coops
Drives: 2010 camaro ss white
Top notch seller, i bought my Slp super charger from him, it look and perform like new
Coop
Coops is offline   Reply With Quote
Old 02-21-2021, 10:30 PM   #3
Whitlow
Whitlow's Avatar
Drives: Chevrolet Camaro
I'm interested in this can you contact me so we can work everything out.
Thanks
Sent from my SM-G781U1 using Tapatalk
Whitlow is offline   Reply With Quote
Old 02-22-2021, 08:43 AM   #4
jokrz187
jokrz187's Avatar
Drives: 2015 1SS
I would like to be next if that deal does not work out
Custom TSP Stage 2 Cam/GPI intake Ported Rod Mod /VARARAM CAI/Mishimoto Catch Can/1 LE front & rear sway bars/ engine cover/fuse box custom painted, strut tower brace, Texas Speed LT, Hi Flo Cats, Magnum Tru-X pipe, NGK Spark Plugs, PCM Spark Plug Wire, Painted Calipers, CF Spoiler w/wicker bill.
jokrz187 is offline   Reply With Quote
Old 02-22-2021, 10:49 PM   #5
Mkoppes
Sold!
Old 04-09-2021, 03:32 AM   #6
csorrentini
csorrentini's Avatar
Drives: 2010 Orange 2SS/RS
do you prefer the zl1 over this? I was actually looking at the same either zl1 full rear-end swap or just up to 3.91 with Eaton and such. zl1 is 3.7 and heavier so would love to know your thoughts.
csorrentini is offline   Reply With Quote
