Old 02-22-2021, 04:39 PM   #1
Maroon 6.2L SS
Maroon 6.2L SS's Avatar
Drives: 2010 Camaro SS A6
Driving around or thru waterpit (tire size)
Hey all. Right now I have 235/55/18 radial tires on the front on 18" drag rims. I want to buy 225/65/17 radial tires on the front on 17" drag rims. I have drag radials on the back. I currently drive around the waterpit and back in. With this new front tire size being narrower, do you think I could drive thru the waterpit now then do a burnout, or, do you think I should still drive around and back in??? Not really sure the rules/best practices with front tire size and waterpit etc...
Maroon 6.2L SS is offline   Reply With Quote
Old 02-23-2021, 12:30 AM   #2
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
I drive through it. No way around it at my track. I wouldn't overthink it
ttshovel is offline   Reply With Quote
Old 02-23-2021, 07:09 AM   #3
Vegas Bound
Drives: 2013 Sparkly Red One
It's not really the tire but but the tread pattern. I run M&H Racemaster and roll right through the water box.
Vegas Bound is offline   Reply With Quote
Old 02-23-2021, 08:02 AM   #4
BuddyLee
BuddyLee's Avatar
Drives: 2013 Camaro 2SS/RS
Contrary to the photo on the left I quit doing the burnout for both cars and as a result the quarter times did not change. Still low 13s high 12s for both cars at around 100 mph without tire spin off the line. Maybe if I went back to burnout I could pick up a 10th or so?
BuddyLee is offline   Reply With Quote
Old 03-25-2021, 04:08 PM   #5
bayarea408
bayarea408's Avatar
Drives: T
low 13's at around 100 sounds like a power limitation more so than rubber. What kind of 60 ft times are you cutting?
bayarea408 is offline   Reply With Quote
