Old 02-24-2021, 06:30 PM   #1
RupertPupkin
Drives: 2014 Camaro SS 1Le
Aftermarket FI and road trips?
Anyone here ever done a long ass road trip with their aftermarket boosted setup? I want to take my Camaro to Virginia and visit my brother. Besides the obvious of me getting annihilated with gas, what else I should keep a look out for
Chicago to Virginia.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 02-24-2021, 06:48 PM   #2
Silver14
Drives: 2014 SIM 2SS
I haven’t taken any road trips with my agp setup, but I’m confident it’d be fine. Where in VA? There’s a lot of fun mountain roads in the SW part of the state, you could even look into taking a day trip to Deals Gap if it’s not too far.
How long have you been supercharged? Any issues in that time? If not, sounds like it’d be just another drive
Maybe pack a spare belt, oil, coolant, and a small toolkit for emergencies.
Silver14 is offline   Reply With Quote
Old 02-24-2021, 07:05 PM   #3
RupertPupkin
My bro’s in the navy, so Norfolk. I’ve had the blower since last May. Tune hasn’t been the best, but I’m going to a different tuner this March 7th. Going to pulley down, fix drivability and fix my hot starts.
I want to test the twisties if there are some along the way. Probably bring a 5 gallon fuel tank also.
730whp: 630Trq
Old 02-24-2021, 07:08 PM   #4
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Find where all the e85 stations are on the way.
Maybe switch to 93 for the trip.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 02-24-2021, 07:31 PM   #5
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
Keep an eye on motor and the centri oil. Maybe take an extra belt. And, of course tools.
I've taking my SBE LS3 with AGP TT on an 800 mile round trip (with race events midway) with no issues. Good tune, FF sensor but ran 91 on the road trip with E85 at the events.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 02-24-2021, 08:12 PM   #6
RupertPupkin
I run flex...
730whp: 630Trq
Old 02-25-2021, 03:27 PM   #7
bayarea408
bayarea408's Avatar
Drives: T
My daily driver was down and i needed to get from San Diego to Sacramento for a wedding. i did the best i could to make sure everything looked perfect and threw my suit in the car and took off. I took very basic tools and 2 cans of Torco encase i was stuck pouring shitty gas. I took turbo stuff with me in the event i REALLY needed it. Hoses, clamps an extra filter. I even brought 2 quarts of oil and 2 spark plugs i had sitting around. Round trip, only thing that happened was the front sway bar bushing popped out and made a rattle for the last 200 miles.
I'd for sure bring a belt OR TWO if i were you, and the correct tools to deal with that.
bayarea408 is offline   Reply With Quote
Old 02-25-2021, 10:08 PM   #8
Rem0v3r
Drives: 2013 ss2 vert l99
You should be ok.. elevation changes may effect you depending on how your tune is..
Rem0v3r is offline   Reply With Quote
Old 02-26-2021, 05:33 AM   #9
Yellow 1
Grumpy Grey-haired Guy
Yellow 1's Avatar
Drives: Camaro, Corvette & Merc C300(daily)
I'm only at 7lb boost so fuel availability not an issue. Happily drive mine into and around Europe on 2500 mile roadtrips; I take a blower belt and the usual bulbs, fuses and a few hand tools. Never had any issues. I probably worry more about punctures and the dreaded space-saver tyre fitment...
Yellow 1 is offline   Reply With Quote
Old 02-26-2021, 07:57 AM   #10
RupertPupkin
How will it be affected?
730whp: 630Trq
Old 02-26-2021, 11:17 AM   #11
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
I drove mine from Albuquerque, NM to Sanford, NC (~1500 miles), and from Sanford, NC to Orlando, FL.....all without issue. Also, I averaged about 22mpg on 93 octane.
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 02-26-2021, 12:01 PM   #12
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
That's not bad at all. I'm bring my car down to CSP on the 8th from Long Island so this will be the cars first long trip (about 2 hours depending).
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 02-26-2021, 12:39 PM   #13
dreksnot
dreksnot's Avatar
For instance, going from a higher elevation to a lower elevation with a SC, you can make more boost. If you're tuned for X amount of boost at elevation then traverse to a lower elevation, you can make X+more, and if you're not tuned for it or already pushing the envelope for fueling (or head gaskets), you can over"power" your setup, or run lean. The tunes have barometric pressure adjustments in there to compensate for the changes; however, most tuners don't touch them (I'm not sure how necessary it is to touch them). I believe with general (daily style of driving), your trims will make any necessary adjustments for fueling. But, if you plan to race it, be aware.
Old 02-26-2021, 12:43 PM   #14
Morgan.13
Drives: 2011 camaro 1ss
I’ve had no issues doing 8+hour trips. Made a trip to the Woodward dream cruise in Detroit a couple years ago when I had my torqstorm set up.
Morgan.13 is offline   Reply With Quote
